주요 콘텐츠로 건너뛰기
Vernee Thor Screen Replacement
필요한 것
  1. 주의: 1-4 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
    Vernee Thor Screen Replacement, Prepare your phone: 1 단계, 이미지 1/1
    • Before you proceed, discharge your battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Shut down your phone.
    • Set the phone down on a soft surface with space to store removed parts safely.
    • Unclip and remove the rear cover,
    • Remove any SIM/MicroSD cards.
    • Unscrew 12 black screws. A magnet is helpful for storing them. Try a fridge magnet face down.
    • Put adhesive tape over the volume and power buttons so they don't get lost,
  2. Vernee Thor Screen Replacement, Remove the frame: 2 단계, 이미지 1/1
    • Use a pick or your thumbnail around the display bezel to separate the frame from the phone.
    • Set aside the frame being careful not to lose the volume and power buttons.
    • If the metal battery shield did not come off with the frame, lift it off and put it with the frame.
  3. Vernee Thor Screen Replacement, Disconnect the battery: 3 단계, 이미지 1/1
    • Gently pry the battery plug up as shown.
    • Take care to only pry up on the battery connector, and not the socket on the logic board. If you pry up on the logic board socket, you may break the connector entirely.
    • Bend the cable up so the plug can't touch the board.
  4. Vernee Thor Screen Replacement, Remove the battery: 4 단계, 이미지 1/1
    • Unpick the white tabs from the top of the battery and pull gently and slowly as shown. Be careful not to snag the tapes. If both tapes come out cleanly the battery will be free. Hold the battery down with your other hand.
    • If the white tapes snap under the battery, gently pry the long edges of the battery away from the metal midframe with a flat plastic pry tool such as a bank card.
    • Be careful not to damage the flat cable underneath the battery!
    • Remove the motherboard by carefully prying up the LCD connector, removing one black screw, and releasing the clamp that holds the flexible cable for the buttons
    • Be careful when you lift the board out so as not to disturb the cameras which you can leave attached to the board.
    • Transfer the earpiece speaker and the sensor block to the new screen before reinstalling the motherboard
    • Be careful to tuck the cameras gently into place.
    • Don't touch the camera lenses!
    • Gently peel up the cable that joins the motherboard to the daughterboard and transfer it along with the coaxial cable.
    • Transfer the daughterboard to the new screen.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Tim
회원 가입일: 08/31/10
1,423 평판
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 1,406
