소개
The battery removal
Removing the Battery is discussed in service manual revision D:
- Chapter 4: Assembly and Disassembly, Pg 60-61
PLEASE NOTE: This repair guide was developed by a student iFixit team based on Viasys/CareFusion's own service manual. Neither iFixit nor this repair guide is endorsed by or affiliated with Viasys or CareFusion.
필요한 것
Remove the ‘rubber collar’ located at the UIM rear neck, by grasping one of the two rubber tabs at the bottom. Pull firmly in an “arcing” motion.
Check to see if the exhalation filter assembly is installed, if it is, remove the exhalation filter assembly.
Rotate the metal locking lever on the lower right of the ventilator body forward to an open position.
Remove the exhalation filter assembly from the ventilator body by pulling straight down.
Locate metal top cover
Remove the 19 SEMS screws, (3) on the left side (5) on the right sife and (11) on top.
Disconnect the internal batteries
Disconnect the battery fuse holder by pulling straight back on the two faston connectors.
