소개
Removing the Exhalation Corner Assembly is a prerequisite step before removing the metal top cover and replacing the internal battery among other processes.
Removing the Exhalation Corner Assembly is discussed in service manual revision D:
- Chapter 4: Assembly and Disassembly, Pg 51-52
PLEASE NOTE: This repair guide was developed by a student iFixit team based on Viasys/CareFusion's own service manual. Neither iFixit nor this repair guide is endorsed by or affiliated with Viasys or CareFusion.
Check to see if the exhalation filter assembly is installed, if it is, remove the exhalation filter assembly.
Rotate the metal locking lever on the lower right of the ventilator body forward to an open position.
Remove the exhalation filter assembly from the ventilator body by pulling straight down.
To reassemble your device, follow the steps in the reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
