주요 콘텐츠로 건너뛰기
Victrola Journey Stylus Replacement
필요한 것
  1. Victrola Journey Stylus Replacement, Victrola Record Player Stylus: 1 단계, 이미지 1/3 Victrola Journey Stylus Replacement, Victrola Record Player Stylus: 1 단계, 이미지 2/3 Victrola Journey Stylus Replacement, Victrola Record Player Stylus: 1 단계, 이미지 3/3
    • Open your record player.
  2. Victrola Journey Stylus Replacement: 2 단계, 이미지 1/3 Victrola Journey Stylus Replacement: 2 단계, 이미지 2/3 Victrola Journey Stylus Replacement: 2 단계, 이미지 3/3
    • Carefully pry off the old stylus with a flat head screwdriver.
    • The stylus should hinge away from you.
  3. Victrola Journey Stylus Replacement: 3 단계, 이미지 1/2 Victrola Journey Stylus Replacement: 3 단계, 이미지 2/2
    • Remove the new stylus from its packaging.
    • Be careful to not bend the needle.
  4. Victrola Journey Stylus Replacement: 4 단계, 이미지 1/2 Victrola Journey Stylus Replacement: 4 단계, 이미지 2/2
    • Place the new stylus onto the arm hinging from the back to the front.
    • You should hear the plastic "snap" into place.
  5. Victrola Journey Stylus Replacement: 5 단계, 이미지 1/1
    • After this you should be done! The last step is to take out that record you've been wanting to hear and start jamming out!
결론
This is a replacement almost anyone can do. As a vinyl owner its important to replace your styluses in order to prevent extra wear and tear on your records.
다른 한 분이 해당 안내서를 완성하였습니다.
Blake Fleer
회원 가입일: 03/18/24
121 평판
안내서 1개 작성함
CSU Los Angeles, Team 1-57, Harris Spring 2024 CSU Los Angeles, Team 1-57, Harris Spring 2024 회원
CSULA-HARRIS-S24S1G57
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 18
전체 시간: 38
