주요 콘텐츠로 건너뛰기
Video Guide Rancilio Silvia Grouphead Screen And Gasket Replacement Grouphead Gasket & Screen Replacement
필요한 것
    • Identification instructions.
    • Remove water tank, hoses, and tuck them back in the machine.
    • Remove drip tray. Flip the machine upside down.
    • Remove screen screw with flat head screwdriver.
    • Remove old screen and diffuser.
    • Remove and soak diffuser in Joe Glo coffee cleaner.
    • On version 3 you will need to remove and soak the brass disc as well.
    • Pry the gasket up with the sharp tip of the awl.
    • Carefully remove old gasket.
    • Use Joe Glo coffee cleaner and hot water to soak the grouphead for 10-15 minutes.
    • A dental pick works great for cleaning the grouphead.
    • Use a small flathead to clean the bottom surface of the grouphead.
    • A small stainless steel brush works well. They can be found at your local hardware store.
    • Use a paper towel / regular towel to soak the dirty water from the grouphead.
    • Use the compressed air can to clean any excess water or coffee.
    • Last but not least, use the pick on the top and bottom rails to remove last bits of coffee debris.
    • Remove parts from bag.
    • Take the new gasket and install it with the lettering down.
    • Use a 1/4 inch flat punch to push down the gasket to ensure its nice and flat.
    • Insert the diffuser with the water channels facing down.
    • Use an 8mm socket wrench to tighten the screw.
    • Careful not to over tighten and break screw. It will be extremely difficult to remove.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Samuel Kanenwisher
회원 가입일: 08/11/12
1,230 평판
안내서 2개 작성하였습니다
Kanen Coffee: Espresso Machines Kanen Coffee: Espresso Machines 회원
Business
1 회원
안내서 2개 작성하였습니다
댓글 7개
Perfect - Just what I needed for my machine.
casper.svendsen - 답글
Nice job! Made it easy to clean and install new partS.
Dan Myall - 답글
very well done. going to do it with my silvia this weekend.
Tom Manaves - 답글
Best version I’ve seen so far. Showing how it’s done on a dirty machine helps
Richard G - 답글
Great!!! I’m assuming the fully assembled backflush procedure is unnecessary after this. But I was wondering if there are any hidden crevices that backflush would get to. This is more serious than you think in my case… I’m resurrecting a rarely used, 15 year old V1 that has NEVER been serviced.
Jeff Vandegrift - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 41
전체 시간: 9,397
