소개
This guide is meant to teach the reader to install a new viewfinder mirror and lens. If the lens or mirror are no longer working or broken, this guide will help the reader replace them with new ones.
도구
부품
부품은 필요하지 않습니다.
Unless otherwise stated, use a phillips #00 screwdriver to remove screws.
Remove the two 4.70mm screws in the bottom of the plastic casing.
Remove the two screws securing the electric strip casing on the back of the camera.
다른 3명이 해당 안내서를 완성하였습니다.
