주요 콘텐츠로 건너뛰기
Vinotemp VT-12TEDi Power Cord Replacement
필요한 것
  1. Vinotemp VT-12TEDi Power Cord Replacement, Power Cord: 1 단계, 이미지 1/2 Vinotemp VT-12TEDi Power Cord Replacement, Power Cord: 1 단계, 이미지 2/2
    • Remove nine 12mm Phillips screws from the upper back panel.
    • Remove three 12mm Phillips screws inset under the back panel.
    • As soon as the screws are removed, the panel will fall freely.
    • When replacing the twelve 12mm Phillips screws, do not tighten the fasteners until all twelve screws have been loosely fitted back onto the cooler. This will ensure the flimsy metal casing will not warp.
  2. Vinotemp VT-12TEDi Power Cord Replacement: 2 단계, 이미지 1/1
    • Power Cord Fastener
    • Ground
    • Motherboard
    • Heat Sink Fan
    • Heat Sink
  3. Vinotemp VT-12TEDi Power Cord Replacement: 3 단계, 이미지 1/3 Vinotemp VT-12TEDi Power Cord Replacement: 3 단계, 이미지 2/3 Vinotemp VT-12TEDi Power Cord Replacement: 3 단계, 이미지 3/3
    • Remove two 7mm Hex Nuts.
    • Clearance is minimal and these screws are very tight. You will likely need a socket wrench to avoid stripping.
    • If the white plastic components stick, pry them apart with a metal spudger. Don't pull on the power cord to get plastic pieces to separate.
  4. Vinotemp VT-12TEDi Power Cord Replacement: 4 단계, 이미지 1/2 Vinotemp VT-12TEDi Power Cord Replacement: 4 단계, 이미지 2/2
    • Remove one 12mm Phillips screw securing ground.
  5. Vinotemp VT-12TEDi Power Cord Replacement: 5 단계, 이미지 1/3 Vinotemp VT-12TEDi Power Cord Replacement: 5 단계, 이미지 2/3 Vinotemp VT-12TEDi Power Cord Replacement: 5 단계, 이미지 3/3
    • Remove power cable from motherboard.
    • Pinch cable connector to release it from the motherboard, then pull.
  6. Vinotemp VT-12TEDi Power Cord Replacement: 6 단계, 이미지 1/1
    • Your power cord is removed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jeff Snyder
회원 가입일: 02/07/13
8,446 평판
안내서 4개 작성하였습니다
iFixit iFixit 회원
Community
141 회원들
안내서 17,709개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 15
전체 시간: 774
