주요 콘텐츠로 건너뛰기
Vintage Mini Vornado Fan Blade Replacement
필요한 것
  1. Vintage Mini Vornado Fan Blade Replacement, Fan Blade: 1 단계, 이미지 1/2 Vintage Mini Vornado Fan Blade Replacement, Fan Blade: 1 단계, 이미지 2/2
    • Prop the cap out of each hole with a pry tool to remove the blade cap.
    • To remove the blade cap, you will need to pop out three different areas of the cap from the fan. There are three small holes around the perimeter of the fan that the cap is secured into.
  2. Vintage Mini Vornado Fan Blade Replacement: 2 단계, 이미지 1/1
    • Face the front of the fan and pull the blade directly towards you to loosen it.
    • Pull the blade out of the rod.
    • Take note of the blade's orientation.
  3. Vintage Mini Vornado Fan Blade Replacement: 3 단계, 이미지 1/1
    • If you have purchased a new blade, make sure the orientation matches the one you just removed.
  4. Vintage Mini Vornado Fan Blade Replacement: 4 단계, 이미지 1/1
    • Use a cloth to dust the blade or other interior areas of the fan.
  5. Vintage Mini Vornado Fan Blade Replacement: 5 단계, 이미지 1/1
    • Place the blade back inside of the fan.
    • The blade should fit snug when the rod is fully inserted.
  6. Vintage Mini Vornado Fan Blade Replacement: 6 단계, 이미지 1/2 Vintage Mini Vornado Fan Blade Replacement: 6 단계, 이미지 2/2
    • Place the blade cap on and secure it into the three holes.
    • Use a pry tool with a cloth to help apply pressure and push the cap into place.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Claire Minahan
회원 가입일: 02/01/23
169 평판
안내서 1개 작성함
Cal Poly, Team 2-3, Johann Winter 2023 Cal Poly, Team 2-3, Johann Winter 2023 회원
CPSU-JOHANN-W23S2G3
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 46
전체 시간: 425
