After years of use, viola strings may become worn out or may snap. This guide will show how to replace broken or worn out strings one at a time. Viola strings from left to right are ordered C, G, D, A.
Make sure the hole is in the correct area and that the inserted string does not overlap other strings. For example, the C string hole should be to the left of the G string.
Insert the ball side of the string into the fine tuner area. If the string does not reach, loosen the tuning peg until it slides in easily. Make sure to also align the string with the bridge.
