주요 콘텐츠로 건너뛰기
Visual Land Prestige 10 Digitizer Replacement
필요한 것
  1. Visual Land Prestige 10 Digitizer Replacement, Back Case: 1 단계, 이미지 1/3 Visual Land Prestige 10 Digitizer Replacement, Back Case: 1 단계, 이미지 2/3 Visual Land Prestige 10 Digitizer Replacement, Back Case: 1 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    구매
    • Remove the 3mm screws from bottom of tablet with the precision screwdriver and place on magnetic mat. label where they came from.
    • All screws throughout this guide are the same 3mm size.
  2. Visual Land Prestige 10 Digitizer Replacement: 2 단계, 이미지 1/3 Visual Land Prestige 10 Digitizer Replacement: 2 단계, 이미지 2/3 Visual Land Prestige 10 Digitizer Replacement: 2 단계, 이미지 3/3
    • Using the spudger, create a small opening to be used to open the back case.
    • While holding the case open, insert the plastic opening tool to get a larger opening.
    • Once you have a slight opening, insert the spudger and work around the edges, separating the back plate from the front.
  3. Visual Land Prestige 10 Digitizer Replacement: 3 단계, 이미지 1/3 Visual Land Prestige 10 Digitizer Replacement: 3 단계, 이미지 2/3 Visual Land Prestige 10 Digitizer Replacement: 3 단계, 이미지 3/3
    • now that the case is open, carefully remove the speakers and set aside.
  4. Visual Land Prestige 10 Digitizer Replacement: 4 단계, 이미지 1/2 Visual Land Prestige 10 Digitizer Replacement: 4 단계, 이미지 2/2
    • Gently remove the speakers from the back case with tweezers and set the case aside.
  5. Visual Land Prestige 10 Digitizer Replacement, Battery: 5 단계, 이미지 1/3 Visual Land Prestige 10 Digitizer Replacement, Battery: 5 단계, 이미지 2/3 Visual Land Prestige 10 Digitizer Replacement, Battery: 5 단계, 이미지 3/3
    • Remove yellow tape from surrounding components.
  6. Visual Land Prestige 10 Digitizer Replacement: 6 단계, 이미지 1/3 Visual Land Prestige 10 Digitizer Replacement: 6 단계, 이미지 2/3 Visual Land Prestige 10 Digitizer Replacement: 6 단계, 이미지 3/3
    • insert the spudger and gently work around and underneath the battery.
    • With the battery separated from the LCD Display, set it aside.
    • The battery is held down by very strong adhesive.
  7. Visual Land Prestige 10 Digitizer Replacement: 7 단계, 이미지 1/1
    • Desolder and remove the 2 wires from the motherboard.
    • Use caution when desoldering to avoid damage to yourself or to the components.
  8. Visual Land Prestige 10 Digitizer Replacement, Front Facing Camera: 8 단계, 이미지 1/3 Visual Land Prestige 10 Digitizer Replacement, Front Facing Camera: 8 단계, 이미지 2/3 Visual Land Prestige 10 Digitizer Replacement, Front Facing Camera: 8 단계, 이미지 3/3
    • Locate the Camera Housing. Gently grip and lift the small black tab until you feel an audible click.
    • Gently remove the connector by pulling straight out, gripping the black connector head or as close as possible.
    • Gently grip and pull up the front camera, covered by protective adhesive foam.
    • Set aside the Camera housing.
  9. Visual Land Prestige 10 Digitizer Replacement, Motherboard: 9 단계, 이미지 1/3 Visual Land Prestige 10 Digitizer Replacement, Motherboard: 9 단계, 이미지 2/3 Visual Land Prestige 10 Digitizer Replacement, Motherboard: 9 단계, 이미지 3/3
    • Locate the LCD Connector.
    • Using tweezers, grip the small black tab connected to the white plastic.
    • Gently lift the tab towards you until it clicks.
    • Remove the connector by pulling straight out, gripping the black connector head.
  10. Visual Land Prestige 10 Digitizer Replacement: 10 단계, 이미지 1/3 Visual Land Prestige 10 Digitizer Replacement: 10 단계, 이미지 2/3 Visual Land Prestige 10 Digitizer Replacement: 10 단계, 이미지 3/3
    • Locate the Touchscreen connector and grip the forward-most black tab with the tweezers.
    • Lift the tab towards you until you feel an audible click.
    • Gently remove the connector by pulling straight out, gripping the black connector head.
  11. Visual Land Prestige 10 Digitizer Replacement: 11 단계, 이미지 1/2 Visual Land Prestige 10 Digitizer Replacement: 11 단계, 이미지 2/2
    • Gently lift up the WiFi antenna and set aside.
  12. Visual Land Prestige 10 Digitizer Replacement: 12 단계, 이미지 1/2 Visual Land Prestige 10 Digitizer Replacement: 12 단계, 이미지 2/2
    • Locate and remove the screws holding the volume and hold button controller. Set screws aside on magnetic mat and label them.
    • Gently lift up on the controller and leave it hanging loose.
  13. Visual Land Prestige 10 Digitizer Replacement: 13 단계, 이미지 1/2 Visual Land Prestige 10 Digitizer Replacement: 13 단계, 이미지 2/2
    • Remove screws located on motherboard.
    • Place on magnetic mat and label them
    • Gently remove the Motherboard and any wires connected to it and set it aside on a static free surface.
  14. Visual Land Prestige 10 Digitizer Replacement, LCD Display: 14 단계, 이미지 1/3 Visual Land Prestige 10 Digitizer Replacement, LCD Display: 14 단계, 이미지 2/3 Visual Land Prestige 10 Digitizer Replacement, LCD Display: 14 단계, 이미지 3/3
    • Remove the screws and plastic tabs holding the LCD Display and place them on the magnetic mat. Label them.
    • Gently remove the LCD Display and backlight by lifting up the LCD Connector with your fingers.
    • Set aside the LCD Assembly.
    • The LCD display and backlight are separated from one another. Be sure to remember how they are aligned when putting the device back together.
  15. Visual Land Prestige 10 Digitizer Replacement, Digitizer: 15 단계, 이미지 1/1
    • Simply lift up the loose metal frame and set aside.
  16. Visual Land Prestige 10 Digitizer Replacement: 16 단계, 이미지 1/3 Visual Land Prestige 10 Digitizer Replacement: 16 단계, 이미지 2/3 Visual Land Prestige 10 Digitizer Replacement: 16 단계, 이미지 3/3
    • Be extremely careful removing the touchscreen, avoiding sharp glass and hot surfaces.
    • Using the heating pad, heat the edges of the touchscreen to loosen the adhesive.
    • using the spudger, slowly and gently work around the edges, removing the touchscreen.
    • The Tablet we used came with a shattered screen, making this step much more difficult.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Connor Reese
회원 가입일: 04/08/15
1,298 평판
안내서 6개 작성하였습니다
댓글 한 개
Great write up, but have a question . Could you heat up the adhesive for the digitizer like an iPad and remove it without taking everything apart?
Michael - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 2,198
