주요 콘텐츠로 건너뛰기
Visual Land Prestige 7L Front Facing Camera Replacement
필요한 것
  1. Visual Land Prestige 7L Front Facing Camera Replacement, Back Panel: 1 단계, 이미지 2개 중 1개 Visual Land Prestige 7L Front Facing Camera Replacement, Back Panel: 1 단계, 이미지 2개 중 2개
    • Remove the two 8mm Phillips Head screws located at the bottom of your device.
  2. Visual Land Prestige 7L Front Facing Camera Replacement: 2 단계, 이미지 3개 중 1개 Visual Land Prestige 7L Front Facing Camera Replacement: 2 단계, 이미지 3개 중 2개 Visual Land Prestige 7L Front Facing Camera Replacement: 2 단계, 이미지 3개 중 3개
    • Insert the spudger between the two pieces of the case around the media ports and pry them apart.
    • We found the best way to get the spudger inside the case was to insert in into the SD card slot. Be sure to only insert the spudger a shallow amount and be careful not to damage any of the inside of the device.
    • Finish unsnapping each plastic piece holding the device together along the bottom.
  3. Visual Land Prestige 7L Front Facing Camera Replacement: 3 단계, 이미지 3개 중 1개 Visual Land Prestige 7L Front Facing Camera Replacement: 3 단계, 이미지 3개 중 2개 Visual Land Prestige 7L Front Facing Camera Replacement: 3 단계, 이미지 3개 중 3개
    • Move the spudger down the rest of the case, separating each side, and finally the top.
    • Pull the back off and place it to the side.
    • Without a back panel for protection, be sure place your device on the table screen-side down to avoid damaging the internal circuitry.
  4. Visual Land Prestige 7L Front Facing Camera Replacement, Front Facing Camera: 4 단계, 이미지 2개 중 1개 Visual Land Prestige 7L Front Facing Camera Replacement, Front Facing Camera: 4 단계, 이미지 2개 중 2개
    • Remove the adhesive padding.
  5. Visual Land Prestige 7L Front Facing Camera Replacement: 5 단계, 이미지 2개 중 1개 Visual Land Prestige 7L Front Facing Camera Replacement: 5 단계, 이미지 2개 중 2개
    • Unclip the connector that attaches the camera to the motherboard.
    • For more information on unclipping connectors see this How To Guide
    • Do not pull on the camera until you're sure that it's unclipped, the gold connection will rip.
    • Gently pop the camera out of the connector and off the case.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Greg Azzalina
회원 가입일: 01/28/15
263 평판
안내서 1개를 작성함
Penn State, Team 2-25, Kaschak Winter 2015 Penn State, Team 2-25, Kaschak Winter 2015 회원
PSU-KASCHAK-W15S2G25
4 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 8
전체 시간: 367
