주요 콘텐츠로 건너뛰기
Visual Land Prestige 7L Screen Replacement
필요한 것
  1. Visual Land Prestige 7L Screen Replacement, Back Panel: 1 단계, 이미지 2개 중 1개 Visual Land Prestige 7L Screen Replacement, Back Panel: 1 단계, 이미지 2개 중 2개
    • Remove the two 8mm Phillips Head screws located at the bottom of your device.
  2. Visual Land Prestige 7L Screen Replacement: 2 단계, 이미지 3개 중 1개 Visual Land Prestige 7L Screen Replacement: 2 단계, 이미지 3개 중 2개 Visual Land Prestige 7L Screen Replacement: 2 단계, 이미지 3개 중 3개
    • Insert the spudger between the two pieces of the case around the media ports and pry them apart.
    • We found the best way to get the spudger inside the case was to insert in into the SD card slot. Be sure to only insert the spudger a shallow amount and be careful not to damage any of the inside of the device.
    • Finish unsnapping each plastic piece holding the device together along the bottom.
  3. Visual Land Prestige 7L Screen Replacement: 3 단계, 이미지 3개 중 1개 Visual Land Prestige 7L Screen Replacement: 3 단계, 이미지 3개 중 2개 Visual Land Prestige 7L Screen Replacement: 3 단계, 이미지 3개 중 3개
    • Move the spudger down the rest of the case, separating each side, and finally the top.
    • Pull the back off and place it to the side.
    • Without a back panel for protection, be sure place your device on the table screen-side down to avoid damaging the internal circuitry.
  4. Visual Land Prestige 7L Screen Replacement, Screen: 4 단계, 이미지 3개 중 1개 Visual Land Prestige 7L Screen Replacement, Screen: 4 단계, 이미지 3개 중 2개 Visual Land Prestige 7L Screen Replacement, Screen: 4 단계, 이미지 3개 중 3개
    • Remove the tape holding the motherboard, wires, and connecters in place.
  5. Visual Land Prestige 7L Screen Replacement: 5 단계, 이미지 3개 중 1개 Visual Land Prestige 7L Screen Replacement: 5 단계, 이미지 3개 중 2개 Visual Land Prestige 7L Screen Replacement: 5 단계, 이미지 3개 중 3개
    • Unclip the three connectors by gently pulling the rear panel up and away from the motherboard.
    • For more information on unclipping connectors see this How To Guide
    • Pull out each of the gold connections.
    • The gold connections will disconnect from the motherboard, but not entirely from the device. Let them sit loosely where they are attached and be careful not to tear them when working in their proximity on the device.
  6. Visual Land Prestige 7L Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the seven 4mm Phillips Head screws that hold the touchscreen panel and motherboard together.
  7. Visual Land Prestige 7L Screen Replacement: 7 단계, 이미지 3개 중 1개 Visual Land Prestige 7L Screen Replacement: 7 단계, 이미지 3개 중 2개 Visual Land Prestige 7L Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Gently flip over the motherboard and begin to use the spudger to pry away the touchscreen panel from the front screen.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Zach
회원 가입일: 01/28/15
486 평판
안내서 2개를 작성함
Penn State, Team 2-25, Kaschak Winter 2015 Penn State, Team 2-25, Kaschak Winter 2015 회원
PSU-KASCHAK-W15S2G25
4 회원들
안내서 4개를 작성함
1가이드 댓글
Muchas gracias por tan importante aporte a la comunidad; desde Colombia  con respeto. Atte. GAZUTEC
GAZUTEC - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 10
전체 시간: 757
