주요 콘텐츠로 건너뛰기
Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement
필요한 것
  1. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement, Digitizer / Front Screen: 1 단계, 이미지 2개 중 1개 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement, Digitizer / Front Screen: 1 단계, 이미지 2개 중 2개
    • At the bottom of the tablet, remove the two 3.6mm screws with a Phillips #000 screwdriver.
  2. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 2 단계, 이미지 2개 중 1개 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Wedge a plastic opening tool into the edges of the tablet to pry it open.
  3. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 3 단계, 이미지 3개 중 1개 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 3 단계, 이미지 3개 중 2개 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 3 단계, 이미지 3개 중 3개
    • Wedge a curved metal spudger under the speaker in order to remove it.
    • The speaker is held in place by an adhesive and can be difficult to remove.
  4. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 4 단계, 이미지 3개 중 1개 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 4 단계, 이미지 3개 중 2개 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 4 단계, 이미지 3개 중 3개
    • Use a Phillips #000 screwdriver to remove the two 3.6mm screws.
  5. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 5 단계, 이미지 3개 중 1개 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 5 단계, 이미지 3개 중 2개 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 5 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to lift the black tab.
  6. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 6 단계, 이미지 2개 중 1개 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Carefully lift and remove the ribbon cable from the black tab.
  7. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 7 단계, 이미지 2개 중 1개 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to remove the camera.
  8. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 8 단계, 이미지 2개 중 1개 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Use a Phillips #000 screwdriver to remove the 3.6mm screw.
  9. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 9 단계, 이미지 3개 중 1개 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 9 단계, 이미지 3개 중 2개 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 9 단계, 이미지 3개 중 3개
    • Lift the tape holding down the battery.
  10. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 10 단계, 이미지 2개 중 1개 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 10 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
  11. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 11 단계, 이미지 3개 중 1개 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 11 단계, 이미지 3개 중 2개 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 11 단계, 이미지 3개 중 3개
  12. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 12 단계, 이미지 2개 중 1개 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 12 단계, 이미지 2개 중 2개
  13. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 13 단계, 이미지 3개 중 1개 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 13 단계, 이미지 3개 중 2개 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 13 단계, 이미지 3개 중 3개
  14. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 14 단계, 이미지 1개 중 1개
    • Safely remove the battery and motherboard from the tablet.
  15. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 15 단계, 이미지 3개 중 1개 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 15 단계, 이미지 3개 중 2개 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 15 단계, 이미지 3개 중 3개
    • Lift the tape on the sides.
  16. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 16 단계, 이미지 3개 중 1개 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 16 단계, 이미지 3개 중 2개 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 16 단계, 이미지 3개 중 3개
    • Use a Phillips #000 screwdriver to remove the three 2.5mm screws.
  17. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 17 단계, 이미지 3개 중 1개 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 17 단계, 이미지 3개 중 2개 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 17 단계, 이미지 3개 중 3개
    • Wedge a metal spudger underneath the LCD screen to remove it.
  18. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: 18 단계, 이미지 1개 중 1개
    • Replace the front screen to replace the digitizer.
결론
작성자
5다른 기여자 명과 함께
Sabrina Scholten
회원 가입일: 09/22/16
621 평판
안내서 6개를 작성함
UC Davis, Team 2-1, Oliver Fall 2016 UC Davis, Team 2-1, Oliver Fall 2016 회원
UCD-OLIVER-F16S2G1
5 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 4
전체 시간: 638
