주요 콘텐츠로 건너뛰기
Visual Land Prestige Elite 7Q Front Camera Replacement
필요한 것
  1. Visual Land Prestige Elite 7Q Front Camera Replacement, Front Camera: 1 단계, 이미지 1/2 Visual Land Prestige Elite 7Q Front Camera Replacement, Front Camera: 1 단계, 이미지 2/2
    • At the bottom of the tablet, remove the two 3.6mm screws with a Phillips #000 screwdriver.
  2. Visual Land Prestige Elite 7Q Front Camera Replacement: 2 단계, 이미지 1/2 Visual Land Prestige Elite 7Q Front Camera Replacement: 2 단계, 이미지 2/2
    • Wedge a plastic opening tool into the edges of the tablet to pry it open.
  3. Visual Land Prestige Elite 7Q Front Camera Replacement: 3 단계, 이미지 1/3 Visual Land Prestige Elite 7Q Front Camera Replacement: 3 단계, 이미지 2/3 Visual Land Prestige Elite 7Q Front Camera Replacement: 3 단계, 이미지 3/3
    • Use a plastic opening tool to lift the black tab holding down the ribbon cable.
  4. Visual Land Prestige Elite 7Q Front Camera Replacement: 4 단계, 이미지 1/2 Visual Land Prestige Elite 7Q Front Camera Replacement: 4 단계, 이미지 2/2
    • Carefully use your finger to pull out the ribbon cable.
  5. Visual Land Prestige Elite 7Q Front Camera Replacement: 5 단계, 이미지 1/2 Visual Land Prestige Elite 7Q Front Camera Replacement: 5 단계, 이미지 2/2
    • Use a plastic opening tool to pull out the camera with the foam backing.
  6. Visual Land Prestige Elite 7Q Front Camera Replacement: 6 단계, 이미지 1/3 Visual Land Prestige Elite 7Q Front Camera Replacement: 6 단계, 이미지 2/3 Visual Land Prestige Elite 7Q Front Camera Replacement: 6 단계, 이미지 3/3
    • Remove the camera from the foam backing.
    • Replace the camera.
결론
Sabrina Scholten
회원 가입일: 09/22/16
621 평판
안내서 6개 작성하였습니다
UC Davis, Team 2-1, Oliver Fall 2016 UC Davis, Team 2-1, Oliver Fall 2016 회원
UCD-OLIVER-F16S2G1
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 4
전체 시간: 140
