주요 콘텐츠로 건너뛰기
Visual Land Prestige Elite 9Q Front and Rear Facing Camera Replacement
필요한 것
  1. Visual Land Prestige Elite 9Q Front and Rear Facing Camera Replacement, Front and Rear Facing Camera: 1 단계, 이미지 1/1
    • Using the large plastic opening tool, start along a side of the device and apply light pressure in the seam between the top and bottom outer covers.
    • Maneuver the smaller plastic opening tool at the spot of the large opening tool and slowly slide along the edge.
    • You should feel each plastic connections begin to loosen.
  2. Visual Land Prestige Elite 9Q Front and Rear Facing Camera Replacement: 2 단계, 이미지 1/1
    • Move tool around each connection, and continue around the device until all connections have been loosened.
    • The user risks damaging the connections if tool is slid to fast
  3. Visual Land Prestige Elite 9Q Front and Rear Facing Camera Replacement: 3 단계, 이미지 1/2 Visual Land Prestige Elite 9Q Front and Rear Facing Camera Replacement: 3 단계, 이미지 2/2
    • Once all connections have been loosened and using a soft surface, place the device onto its screen.
    • Open the casing and lay as shown keeping the speaker wire loose, and the camera component is highlighted in red.
  4. Visual Land Prestige Elite 9Q Front and Rear Facing Camera Replacement: 4 단계, 이미지 1/3 Visual Land Prestige Elite 9Q Front and Rear Facing Camera Replacement: 4 단계, 이미지 2/3 Visual Land Prestige Elite 9Q Front and Rear Facing Camera Replacement: 4 단계, 이미지 3/3
    • Using hook tweezers, gently separate the glued cameras away from the circuit board.
    • Allow each camera to rest on circuit board while proceeding to the ZIF (zero insertion force) on the circuit board.
    • Avoid touching camera lens with the tweezers.
  5. Visual Land Prestige Elite 9Q Front and Rear Facing Camera Replacement: 5 단계, 이미지 1/2 Visual Land Prestige Elite 9Q Front and Rear Facing Camera Replacement: 5 단계, 이미지 2/2
    • Maneuver the hook tweezers to flip up the black hinged ZIF connector to disconnect camera module.
    • After ZIF connector is flipped up, the camera module may be removed.
결론
Aaron
회원 가입일: 07/19/16
316 평판
안내서 2개 작성하였습니다
University of Memphis, Team 1-1, Kim SU 2016 University of Memphis, Team 1-1, Kim SU 2016 회원
UM-KIM-SU16S1G1
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 4
전체 시간: 298
