주요 콘텐츠로 건너뛰기
Visual Land Prestige Elite 9Q Speaker Replacement
필요한 것
  1. Visual Land Prestige Elite 9Q Speaker Replacement, Speaker: 1 단계, 이미지 1/1
    • Using the large plastic opening tool, start along a side of the device and apply light pressure in the seam between the top and bottom outer covers.
    • Maneuver the smaller plastic opening tool at the spot of the large opening tool and slowly slide along the edge.
    • You should feel each plastic connections begin to loosen.
  2. Visual Land Prestige Elite 9Q Speaker Replacement: 2 단계, 이미지 1/1
    • Move tool around each connection, and continue around the device until all connections have been loosened.
    • The user risks damaging the connections if tool is slid to fast.
  3. Visual Land Prestige Elite 9Q Speaker Replacement: 3 단계, 이미지 1/2 Visual Land Prestige Elite 9Q Speaker Replacement: 3 단계, 이미지 2/2
    • Once all connections have been loosened and using a soft surface, place the device onto its screen.
    • Open the casing and lay as shown in the picture keeping the speaker wires loose.
  4. Visual Land Prestige Elite 9Q Speaker Replacement: 4 단계, 이미지 1/2 Visual Land Prestige Elite 9Q Speaker Replacement: 4 단계, 이미지 2/2
    • Using ESD safe tweezers and a spudger, gently remove the glued speaker away from the casing.
    • The speaker is still connected to the motherboard with wire.
  5. Visual Land Prestige Elite 9Q Speaker Replacement: 5 단계, 이미지 1/1
    • Next locate where the speaker's wires attach to the motherboard.
    • Make note of the red and black wires positions, for mixing them can cause permanent damage to your device.
  6. Visual Land Prestige Elite 9Q Speaker Replacement: 6 단계, 이미지 1/2 Visual Land Prestige Elite 9Q Speaker Replacement: 6 단계, 이미지 2/2
    • Before replacing the speaker, it's helpful to disconnect the LCD ribbon allowing sufficient space.
    • Remove the tape, and using hook tweezers, disconnect the LCD ZIF (zero insertion force) connection.
    • The ZIF connection takes manuvering, but the ribbon should be free and pushed out of the way.
  7. Visual Land Prestige Elite 9Q Speaker Replacement: 7 단계, 이미지 1/2 Visual Land Prestige Elite 9Q Speaker Replacement: 7 단계, 이미지 2/2
    • Before disconnecting the speaker, refer to Soldering Tips for proper soldering instructions.
    • Check the connection between the speaker and the motherboard. If it isn’t connected well, re-soldering the joint may fix the speaker.
    • Use a soldering iron the remove the speaker wires.
    • Ensure that each wire and solder connection do not touch. This will damage the device.
    • Note which nodes the wires are connected to, for replacement will occur in this order.
결론
Joseph Justice
회원 가입일: 07/19/16
175 평판
안내서 1개 작성함
University of Memphis, Team 1-1, Kim SU 2016 University of Memphis, Team 1-1, Kim SU 2016 회원
UM-KIM-SU16S1G1
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 193
