주요 콘텐츠로 건너뛰기
Visual Land Prestige Pro 7D Camera Replacement
필요한 것
  1. Visual Land Prestige Pro 7D Camera Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Unscrew the two 4.0mm Phillips head screws found near the ports at the bottom of the device using a PH #00 screwdriver.
  2. Visual Land Prestige Pro 7D Camera Replacement: 2 단계, 이미지 1개 중 1개
    • Be careful when taking the back panel off. The speaker is connected to both the front and back panels, and may get pulled out if you are not gentle when lifting the back panel away.
    • Slide the plastic prying tool in between the front and back panel and pry them apart on all 4 sides.
    • It may be easiest to start on one of the sides, and work your way around the device. The bottom, with the ports, is the most difficult side and can be saved for last.
    • There are small latches that make this difficult. Moderate force may be required to separate the two panels.
  3. Visual Land Prestige Pro 7D Camera Replacement, Front-Facing Camera: 3 단계, 이미지 2개 중 1개 Visual Land Prestige Pro 7D Camera Replacement, Front-Facing Camera: 3 단계, 이미지 2개 중 2개
    • Remove the black pad on the back of the camera by peeling it off.
  4. Visual Land Prestige Pro 7D Camera Replacement: 4 단계, 이미지 1개 중 1개
    • With the bottom of the device facing away from you, pull the camera out of its black housing.
    • The camera will come right out when you lift with your fingers.
  5. Visual Land Prestige Pro 7D Camera Replacement: 5 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use the tweezers to lift the grey connector, connecting the camera ribbon to the circuit board, up from the beige housing. It should rotate up, and allow you to slide the ribbon out from under the connector.
결론
작성자
3다른 기여자 명과 함께
Brandon Kodama
회원 가입일: 10/17/14
229 평판
안내서 1개를 작성함
Cal Poly, Team 10-41, Amido Fall 2014 Cal Poly, Team 10-41, Amido Fall 2014 회원
CPSU-AMIDO-F14S10G41
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 565
