주요 콘텐츠로 건너뛰기
Vivitar DVR 781HD Motherboard Replacement
필요한 것
  1. Vivitar DVR 781HD Motherboard Replacement, Front Case: 1 단계, 이미지 1/3 Vivitar DVR 781HD Motherboard Replacement, Front Case: 1 단계, 이미지 2/3 Vivitar DVR 781HD Motherboard Replacement, Front Case: 1 단계, 이미지 3/3
    • Begin with the camcorder lens up on a clear working surface.
    • Remove the two 4mm Phillips #1 screws holding the switch plate in place. Rotate the device 180 degrees and repeat for the screws on the opposite side.
  2. Vivitar DVR 781HD Motherboard Replacement: 2 단계, 이미지 1/1
    • Slide the plastic opening tool into the seam between the front and back sections of the case and apply a small amount of force to pop the case open.
  3. Vivitar DVR 781HD Motherboard Replacement: 3 단계, 이미지 1/3 Vivitar DVR 781HD Motherboard Replacement: 3 단계, 이미지 2/3 Vivitar DVR 781HD Motherboard Replacement: 3 단계, 이미지 3/3
    • Move the plastic opening tool around the seam and apply force at each step to separate the front plate from the back plate and motherboard.
    • The battery is held to the front half of the case with double-sided tape. Peel it up with a finger, being careful not to damage the battery.
  4. Vivitar DVR 781HD Motherboard Replacement, Motherboard: 4 단계, 이미지 1/2 Vivitar DVR 781HD Motherboard Replacement, Motherboard: 4 단계, 이미지 2/2
    • Using a P1 screwdriver, remove the 4mm screws holding the motherboard into the case.
  5. Vivitar DVR 781HD Motherboard Replacement: 5 단계, 이미지 1/1
    • Gently lift the motherboard, handling it by the edges.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Nathan McDaniel
회원 가입일: 02/13/16
592 평판
안내서 3개 작성하였습니다
IUPUI, Team 54-6, Wilson Spring 2016 IUPUI, Team 54-6, Wilson Spring 2016 회원
IUPUI-WILSON-S16S54G6
3 회원들
안내서 10개 작성하였습니다
댓글 3개
It says no parts required, but it is instructions to replace the motherboard.
There is nothing about getting another motherboard, and how much.
Heki Kahni - 답글
How do you get a motherboard?
Rdam Russell - 답글
Where do we get one?
bikerbarbie29 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 1,418
