주요 콘텐츠로 건너뛰기
Vivitar DVR 781HD Waterproof Case Lens Cover Replacement
필요한 것
  1. Vivitar DVR 781HD Waterproof Case Lens Cover Replacement, Waterproof Case Lens Cover: 1 단계, 이미지 1/1
    • Place waterproof case on flat surface, with the lens cover facing up.
  2. Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: 2 단계, 이미지 1/2 Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: 2 단계, 이미지 2/2
    • Remove the six 4.5mm Phillips #00 screws from the black lens cover trim.
  3. Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: 3 단계, 이미지 1/2 Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: 3 단계, 이미지 2/2
    • While holding the black lens cover trim tight to the case, flip the case over so that the lens cover is rested on your work surface.
  4. Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: 4 단계, 이미지 1/2 Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: 4 단계, 이미지 2/2
    • Apply pressure to the lens cover with your thumb, and use your other fingers to pull up on the case, separating the lens and lens trim from the case.
  5. Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: 5 단계, 이미지 1/2 Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: 5 단계, 이미지 2/2
    • There is a small plastic key on the black bezel that aligns it to the case. Be sure to line this up during reassembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jordan Baum
회원 가입일: 02/13/16
355 평판
안내서 2개 작성하였습니다
IUPUI, Team 54-6, Wilson Spring 2016 IUPUI, Team 54-6, Wilson Spring 2016 회원
IUPUI-WILSON-S16S54G6
3 회원들
안내서 10개 작성하였습니다
댓글 한 개
Hello, do you know where I can acquire a replacement water proof case for my Vivitar DVR 787 HD action camcorder?
Andrew Hinsley - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 15
전체 시간: 1,253
