주요 콘텐츠로 건너뛰기
Vivitar XO 7 Motherboard Replacement
필요한 것
  1. Vivitar XO 7 Motherboard Replacement, Back Cover: 1 단계, 이미지 1/1
    • Remove the two 3mm Phillips #00 screws on the bottom of the tablet.
  2. Vivitar XO 7 Motherboard Replacement: 2 단계, 이미지 1/1
    • With the plastic opening tools, pry open the back cover.
  3. Vivitar XO 7 Motherboard Replacement: 3 단계, 이미지 1/1
    • Remove the back cover from the tablet.
  4. Vivitar XO 7 Motherboard Replacement, Battery: 4 단계, 이미지 1/2 Vivitar XO 7 Motherboard Replacement, Battery: 4 단계, 이미지 2/2
    • Peel off the black pieces of tape from the internal components.
  5. Vivitar XO 7 Motherboard Replacement: 5 단계, 이미지 1/2 Vivitar XO 7 Motherboard Replacement: 5 단계, 이미지 2/2
    • Carefully remove the battery from the tablet.
  6. Vivitar XO 7 Motherboard Replacement: 6 단계, 이미지 1/2 Vivitar XO 7 Motherboard Replacement: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • With the tweezers, firmly grab the wire at the base and pull to disconnect the battery from the motherboard.
  7. Vivitar XO 7 Motherboard Replacement, Speaker: 7 단계, 이미지 1/1
    • Carefully remove the speaker from the metal plate with your hands.
  8. Vivitar XO 7 Motherboard Replacement: 8 단계, 이미지 1/2 Vivitar XO 7 Motherboard Replacement: 8 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • With tweezers, firmly grab the wire at the base and pull to disconnect the speaker from the motherboard.
  9. Vivitar XO 7 Motherboard Replacement, Camera: 9 단계, 이미지 1/1
    • Peel off black tape that is holding the camera in place.
  10. Vivitar XO 7 Motherboard Replacement: 10 단계, 이미지 1/1
    • Carefully disconnect the ribbon cables from the motherboard.
  11. Vivitar XO 7 Motherboard Replacement: 11 단계, 이미지 1/2 Vivitar XO 7 Motherboard Replacement: 11 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using the tweezers, firmly grab wires and pull to disconnect them from the motherboard.
  12. Vivitar XO 7 Motherboard Replacement, Motherboard: 12 단계, 이미지 1/1
    • Disconnect the large golden ribbon cable that is connected to the digitizer. Firmly grab the cable close to the connection and pull to disconnect.
  13. Vivitar XO 7 Motherboard Replacement: 13 단계, 이미지 1/1
    • Remove four 4mm PH00 silver screws from the motherboard.
  14. Vivitar XO 7 Motherboard Replacement: 14 단계, 이미지 1/1
    • Remove two 2mm PH00 black screws from the motherboard.
  15. Vivitar XO 7 Motherboard Replacement: 15 단계, 이미지 1/1
    • Carefully remove the silver cover from the motherboard.
  16. Vivitar XO 7 Motherboard Replacement: 16 단계, 이미지 1/2 Vivitar XO 7 Motherboard Replacement: 16 단계, 이미지 2/2
    • Gently pick up and turn over the motherboard. While turned over, disconnect the last ribbon cable that connects to screen.
결론
James Lunn
회원 가입일: 01/20/15
116 평판
안내서 1개 작성함
USF Tampa, Team 11-1, Blackwell Winter 2015 USF Tampa, Team 11-1, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S11G1
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 944
