주요 콘텐츠로 건너뛰기
Vivotek FD8169 Camera Module Replacement
필요한 것
  1. Vivotek FD8169 Camera Module Replacement, Dome Cover: 1 단계, 이미지 1/1
    • Loosen the outside screw.
  2. Vivotek FD8169 Camera Module Replacement: 2 단계, 이미지 1/1
    • Press down on the side button, and lift up the top dome.
  3. Vivotek FD8169 Camera Module Replacement, Camera Module: 3 단계, 이미지 1/1
    • Remove three screws that connect the camera base to the motherboard using a Phillips #1 screwdriver.
  4. Vivotek FD8169 Camera Module Replacement: 4 단계, 이미지 1/1
    • Lift off the camera base from the motherboard.
  5. Vivotek FD8169 Camera Module Replacement: 5 단계, 이미지 1/1
    • Unscrew the cord from the motherboard.
    • Unplug the remaining connection.
  6. Vivotek FD8169 Camera Module Replacement: 6 단계, 이미지 1/1
    • Unscrew the camera from the camera base with a hex screwdriver on both sides.
  7. Vivotek FD8169 Camera Module Replacement: 7 단계, 이미지 1/1
    • Pull the camera out from the camera base.
결론
Logan Bento
회원 가입일: 10/18/21
121 평판
안내서 1개 작성함
UMass Dartmouth, Team 1-6, Simcock Fall 2021 UMass Dartmouth, Team 1-6, Simcock Fall 2021 회원
UMASSD-SIMCOCK-F21S1G6
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 17
전체 시간: 274
