소개
Using this guide, you will be able to remove a broken battery from the Vizio CT15 in order to replace it with a new one.
필요한 것
Turn the laptop off and remove all power cables.
Remove the six Phillips #0 screws.
Pull the back cover off.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
In case anyone comes across this page looking for the CMOS Battery, it is an ML1220 Battery. I found a comparable replacement of "LeFix ML1220 Rechargeable CMOS Battery Replacement Compatible with ASUS EEE PC 1101HA 1005HA T101MT 1101HAB 1005P,Acer Aspire 5920 5920G 5920 G Series,Fujitsu Amilo Pi 3560 3660 LI3710 LI3910" on Amazon (https://www.amazon.com/LeFix-Rechargeabl...)
