주요 콘텐츠로 건너뛰기
Vizio SmartCast Tablet Remote XR6M Battery Replacement
필요한 것
  1. Vizio SmartCast Tablet Remote XR6M Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 Vizio SmartCast Tablet Remote XR6M Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 Vizio SmartCast Tablet Remote XR6M Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Hold the device in one hand with the screen facing down.
    • Insert the plastic opening tool under the back panel on the side of the device.
    • Slide the plastic opening tool down the side of the device, then repeat this process on all four sides of the device until the back panel pops off.
    • You may hear a popping noise when you pry off the back panel.
  2. Vizio SmartCast Tablet Remote XR6M Battery Replacement: 2 단계, 이미지 3개 중 1개 Vizio SmartCast Tablet Remote XR6M Battery Replacement: 2 단계, 이미지 3개 중 2개 Vizio SmartCast Tablet Remote XR6M Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Use a driver with the T5 bit to remove the 3mm screws attaching the narrow metal plate to the main board.
  3. Vizio SmartCast Tablet Remote XR6M Battery Replacement: 3 단계, 이미지 2개 중 1개 Vizio SmartCast Tablet Remote XR6M Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Slide the pointy end of the nylon spudger under the wires of the battery connector, and gently lift the wires away from the device, freeing the connector from the main board.
  4. Vizio SmartCast Tablet Remote XR6M Battery Replacement: 4 단계, 이미지 2개 중 1개 Vizio SmartCast Tablet Remote XR6M Battery Replacement: 4 단계, 이미지 2개 중 2개
    • To remove adhesive, insert the flat end of the plastic spudger under the battery. Slide it toward the top of the device until the battery pops free.
    • You may hear a popping noise when you pry off the battery.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
tate campbell
회원 가입일: 09/17/18
439 평판
안내서 3개를 작성함
Washington State, Team S2-G3, Hope Fall 2018 Washington State, Team S2-G3, Hope Fall 2018 회원
WSU-HOPE-F18S2G3
4 회원들
안내서 3개를 작성함
5가이드 댓글
Where did you find the replacement battery? I’ve looked everywhere, but the part numbers bring up nothing.
John - 답글
Same as that guy ^^^
gary goodnight - 답글
Yep me too , where can I get the battery ?????
Minus 300 points
Kyle Parker - 답글
More than 6 years and still no response on where to get the replacement 😔
Ryan Alexander - 답글
Donde consigo una bateriade esas?, mi tableta ya no prende quisiera ponerle una nueva!
אלונסו סנדובל - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 24
전체 시간: 2,238
