소개
Problems with charging that cannot be resolved by using a different charger may necessitate battery replacement. Here you will find a simple, step-by-step guide to take apart the tablet on your own, and remove and replace the battery.
필요한 것
Hold the device in one hand with the screen facing down.
Insert the plastic opening tool under the back panel on the side of the device.
Slide the plastic opening tool down the side of the device, then repeat this process on all four sides of the device until the back panel pops off.
To remove adhesive, insert the flat end of the plastic spudger under the battery. Slide it toward the top of the device until the battery pops free.
Hello, my name is Wesley and I would like to know where I can buy a battery for this type of control. My number is (407)907-3273
다른 7명이 해당 안내서를 완성하였습니다.
댓글 2개
Same as that guy ^^^
