주요 콘텐츠로 건너뛰기
Vizio SmartCast Tablet Remote XR6P Haptic Motor Replacement
필요한 것
  1. Vizio SmartCast Tablet Remote XR6P Haptic Motor Replacement, Back Cover: 1 단계, 이미지 1/1
    • Obtain the black plastic spudger tool from the iFixit toolkit. Position the device as shown in the picture. Insert the flat end of the spudger directly in the space above the power button between the back cover and front screen.
  2. Vizio SmartCast Tablet Remote XR6P Haptic Motor Replacement: 2 단계, 이미지 1/1
    • Gently pry up on the plate with the spudger. You may hear some cracking noises as you work the spudger around your device, this is normal.
  3. Vizio SmartCast Tablet Remote XR6P Haptic Motor Replacement: 3 단계, 이미지 1/1
    • Pry around the edges of the tablet with your fingers until you have successfully removed the back of the device.
  4. Vizio SmartCast Tablet Remote XR6P Haptic Motor Replacement, Haptic Motor: 4 단계, 이미지 1/1
    • After removing the back cover, you will be able to gain access to the speaker component.
  5. Vizio SmartCast Tablet Remote XR6P Haptic Motor Replacement: 5 단계, 이미지 1/3 Vizio SmartCast Tablet Remote XR6P Haptic Motor Replacement: 5 단계, 이미지 2/3 Vizio SmartCast Tablet Remote XR6P Haptic Motor Replacement: 5 단계, 이미지 3/3
    • Pry the speaker up gently with the pointy end of the metal spudger.
  6. Vizio SmartCast Tablet Remote XR6P Haptic Motor Replacement: 6 단계, 이미지 1/1
    • Pull the red and blue wires from the green circuit panel.
  7. Vizio SmartCast Tablet Remote XR6P Haptic Motor Replacement: 7 단계, 이미지 1/1
    • When reassembling, you will need to use the soldering iron to solder the red and blue wires back to the circuit board.
결론
Shonna Dempsey
회원 가입일: 10/03/18
159 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 181
