주요 콘텐츠로 건너뛰기
Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement
필요한 것
  1. Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Obtain the black plastic spudger tool from the iFixit toolkit. Position the device as shown in the picture. Insert the flat end of the spudger directly in the space above the power button between the back cover and front screen.
  2. Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement: 2 단계, 이미지 1개 중 1개
    • Gently pry up on the plate with the spudger. You may hear some cracking noises as you work the spudger around your device, this is normal.
  3. Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement: 3 단계, 이미지 1개 중 1개
    • Pry around the edges of the tablet with your fingers until you have successfully removed the back of the device.
  4. Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement, Micro USB Charging Port: 4 단계, 이미지 2개 중 1개 Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement, Micro USB Charging Port: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • The black ribbon can be easily damaged during this step, so proceed with caution.
    • Place the flat end of the black plastic spudger under the black plug and pry up to release the black ribbon. Using the metal tweezers, pull the black ribbon out of the plug.
  5. Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement: 5 단계, 이미지 1개 중 1개
    • Remove all three 3mm-long silver screws using the T5 Torx screwdriver.
  6. Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement: 6 단계, 이미지 3개 중 1개 Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement: 6 단계, 이미지 3개 중 2개 Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement: 6 단계, 이미지 3개 중 3개
    • Place the shovel end of the metal spudger under the speaker and pry upwards to remove the speaker from the device.
    • The speaker is secured to the device with adhesive glue so you may hear cracking noises while prying with the spudger.
  7. Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement: 7 단계, 이미지 2개 중 1개 Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement: 7 단계, 이미지 2개 중 2개
    • Using the tweezers, grab a hold of the Micro USB assembly and gently remove it from the device.
결론
작성자
4다른 기여자 명과 함께
Jordan Adams
회원 가입일: 10/04/18
445 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 5
전체 시간: 346
