주요 콘텐츠로 건너뛰기
Vizio SmartCast Tablet Remote XR6P Top Speaker + WIFI Antenna Replacement
필요한 것
  1. Vizio SmartCast Tablet Remote XR6P Top Speaker + WIFI Antenna  Replacement, Back Cover: 1 단계, 이미지 1/1
    • Obtain the black plastic spudger tool from the iFixit toolkit. Position the device as shown in the picture. Insert the flat end of the spudger directly in the space above the power button between the back cover and front screen.
  2. Vizio SmartCast Tablet Remote XR6P Top Speaker + WIFI Antenna  Replacement: 2 단계, 이미지 1/1
    • Gently pry up on the plate with the spudger. You may hear some cracking noises as you work the spudger around your device, this is normal.
  3. Vizio SmartCast Tablet Remote XR6P Top Speaker + WIFI Antenna  Replacement: 3 단계, 이미지 1/1
    • Pry around the edges of the tablet with your fingers until you have successfully removed the back of the device.
  4. Vizio SmartCast Tablet Remote XR6P Top Speaker + WIFI Antenna  Replacement, Top Speaker + WIFI Antenna: 4 단계, 이미지 1/1
    • During this step, avoid pulling on the red and black wires as they can be easily damaged. Instead, grab only the plug itself.
    • Use the tweezers to grab the power plug connected to the red and black wires. Disconnect the plug by pulling the tweezers away from the device.
  5. Vizio SmartCast Tablet Remote XR6P Top Speaker + WIFI Antenna  Replacement: 5 단계, 이미지 1/3 Vizio SmartCast Tablet Remote XR6P Top Speaker + WIFI Antenna  Replacement: 5 단계, 이미지 2/3 Vizio SmartCast Tablet Remote XR6P Top Speaker + WIFI Antenna  Replacement: 5 단계, 이미지 3/3
    • Place the flat end of the black plastic spudger under the locking tab that holds the tail end of the black ribbon in place. Pry upwards unlocking the tail of the black ribbon. Use the tweezers to remove the black ribbon from the plug.
  6. Vizio SmartCast Tablet Remote XR6P Top Speaker + WIFI Antenna  Replacement: 6 단계, 이미지 1/3 Vizio SmartCast Tablet Remote XR6P Top Speaker + WIFI Antenna  Replacement: 6 단계, 이미지 2/3 Vizio SmartCast Tablet Remote XR6P Top Speaker + WIFI Antenna  Replacement: 6 단계, 이미지 3/3
    • Remove the three 3mm screws holding the WIFI antennae in the device. Use the tweezers to grab and remove the metal plate securing the antennae.
    • Two of the screws are silver, while one is black.
  7. Vizio SmartCast Tablet Remote XR6P Top Speaker + WIFI Antenna  Replacement: 7 단계, 이미지 1/1
    • Remove the WIFI antennae from the device and replace.
결론
Jordan Adams
회원 가입일: 10/04/18
445 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 5
전체 시간: 220
