주요 콘텐츠로 건너뛰기
Vizio Tablet Micro USB Charging Port Replacement
필요한 것
  1. Vizio Tablet Micro USB Charging Port Replacement, Micro USB Charging Port: 1 단계, 이미지 1/3 Vizio Tablet Micro USB Charging Port Replacement, Micro USB Charging Port: 1 단계, 이미지 2/3 Vizio Tablet Micro USB Charging Port Replacement, Micro USB Charging Port: 1 단계, 이미지 3/3
    • Begin by using the plastic opening tool to take off the back of the tablet.
    • Starting from the sides can make the process easier.
  2. Vizio Tablet Micro USB Charging Port Replacement: 2 단계, 이미지 1/1
    • Use the plastic opening tool to disconnect the LCD screen.
  3. Vizio Tablet Micro USB Charging Port Replacement: 3 단계, 이미지 1/1
    • Use the plastic opening tool to disconnect the camera.
  4. Vizio Tablet Micro USB Charging Port Replacement: 4 단계, 이미지 1/1
    • Use the plastic opening tool to disconnect both of the volume buttons.
  5. Vizio Tablet Micro USB Charging Port Replacement: 5 단계, 이미지 1/2 Vizio Tablet Micro USB Charging Port Replacement: 5 단계, 이미지 2/2
    • Then, remove all four of the 2.3 mm Phillips screws.
  6. Vizio Tablet Micro USB Charging Port Replacement: 6 단계, 이미지 1/1
    • Remove the circuit board from the platform.
  7. Vizio Tablet Micro USB Charging Port Replacement: 7 단계, 이미지 1/1
    • Remove the USB port from the circuit board.
  8. Vizio Tablet Micro USB Charging Port Replacement: 8 단계, 이미지 1/1
    • Insert the new USB port onto the circuit board.
  9. Vizio Tablet Micro USB Charging Port Replacement: 9 단계, 이미지 1/1
    • Lastly, fuse the USB port back onto the circuit board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jose
회원 가입일: 05/31/16
125 평판
안내서 1개 작성함
댓글 한 개
Thank you it was very helpful simple and straight to the point
sirhc89chris - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 936
