주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Vizio VTAB1008 Battery Replacement
필요한 것
  1. Vizio VTAB1008 Battery Replacement, Vizio VTAB1008 Back Cover Removal: 1 단계, 이미지 2개 중 1개 Vizio VTAB1008 Battery Replacement, Vizio VTAB1008 Back Cover Removal: 1 단계, 이미지 2개 중 2개
    • Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons.
    • Do not insert the opening tool too far into the tablet as this can damage connectors close to edges of the cover.
    • The angled tip of the opening tool can be wedged into the device by pressing on the back of the opening tool with the thumb. Move the opening tool in a sliding motion to ensure all tabs separate.
    • Corner tabs may require a more forceful prying tool. If needed, carefully insert the metal prying tool into corners to separate the tabs.
  2. Vizio VTAB1008 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Look into the tablet for loose connectors.
    • There are three loose connectors: one for the screen, one for the digitizer, and one for the motherboard. They are held in place by the pressure of the backing and screen assemblies.
    • Flip the backing from the button-less side over, being careful not to separate the ribbon connector from the display screen.
  3. Vizio VTAB1008 Battery Replacement, Battery: 3 단계, 이미지 3개 중 1개 Vizio VTAB1008 Battery Replacement, Battery: 3 단계, 이미지 3개 중 2개 Vizio VTAB1008 Battery Replacement, Battery: 3 단계, 이미지 3개 중 3개
    • Remove the ribbon strip that crosses the battery from both ends.
    • A blue opening tool may be used to assist.
  4. Vizio VTAB1008 Battery Replacement: 4 단계, 이미지 2개 중 1개 Vizio VTAB1008 Battery Replacement: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the connector at the top of the motherboard by pulling out and away from the motherboard.
    • This is the connector with the wires leading to the battery.
    • Tweezers may help.
  5. Vizio VTAB1008 Battery Replacement: 5 단계, 이미지 3개 중 1개 Vizio VTAB1008 Battery Replacement: 5 단계, 이미지 3개 중 2개 Vizio VTAB1008 Battery Replacement: 5 단계, 이미지 3개 중 3개
    • Pull the battery away from the back panel.
    • A metal spudger may be needed to pry the battery from the backing.
    • The battery is glued to the back panel and caution should be used as to not break or rupture the battery pack.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Gilberto Ambriz
회원 가입일: 09/29/16
552 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 56
전체 시간: 1,711
