소개
Hello! This is a guide on how to replace the charging port in your Vizio VTAB1008!
필요한 것
Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons.
Corner tabs may require a more forceful prying tool. If needed, carefully insert the metal prying tool into corners to separate the tabs.
Remove the motherboard by unscrewing the four securing screws with a J1 Phillip's head screwdriver.
다른 한 분이 해당 안내서를 완성하였습니다.
