주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Vizio VTAB1008 Charging Port Replacement
필요한 것
    1. Vizio VTAB1008 Charging Port Replacement, Vizio VTAB1008 Back Cover Removal: 1 단계, 이미지 2개 중 1개 Vizio VTAB1008 Charging Port Replacement, Vizio VTAB1008 Back Cover Removal: 1 단계, 이미지 2개 중 2개
      • Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons.
      • Do not insert the opening tool too far into the tablet as this can damage connectors close to edges of the cover.
      • The angled tip of the opening tool can be wedged into the device by pressing on the back of the opening tool with the thumb. Move the opening tool in a sliding motion to ensure all tabs separate.
      • Corner tabs may require a more forceful prying tool. If needed, carefully insert the metal prying tool into corners to separate the tabs.
      댓글 쓰기
    2. Vizio VTAB1008 Charging Port Replacement: 2 단계, 이미지 1개 중 1개
      • Look into the tablet for loose connectors.
      • There are three loose connectors: one for the screen, one for the digitizer, and one for the motherboard. They are held in place by the pressure of the backing and screen assemblies.
      • Flip the backing from the button-less side over, being careful not to separate the ribbon connector from the display screen.
      댓글 쓰기
    1. Vizio VTAB1008 Charging Port Replacement, Charging Port: 3 단계, 이미지 3개 중 1개 Vizio VTAB1008 Charging Port Replacement, Charging Port: 3 단계, 이미지 3개 중 2개 Vizio VTAB1008 Charging Port Replacement, Charging Port: 3 단계, 이미지 3개 중 3개
      • Remove the motherboard by unscrewing the four securing screws with a J1 Phillip's head screwdriver.
      • 3 of the screws are clearly visible while the 4th is hidden by black tape on the upper left corner of the motherboard.
      댓글 쓰기
    2. Vizio VTAB1008 Charging Port Replacement: 4 단계, 이미지 3개 중 1개 Vizio VTAB1008 Charging Port Replacement: 4 단계, 이미지 3개 중 2개 Vizio VTAB1008 Charging Port Replacement: 4 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Remove both antenna connectors with a blue opening tool/tweezers.
      댓글 쓰기
    3. Vizio VTAB1008 Charging Port Replacement: 5 단계, 이미지 3개 중 1개 Vizio VTAB1008 Charging Port Replacement: 5 단계, 이미지 3개 중 2개 Vizio VTAB1008 Charging Port Replacement: 5 단계, 이미지 3개 중 3개
      • Remove the ribbon connector at the top of the motherboard using the opening tool.
      댓글 쓰기
    4. Vizio VTAB1008 Charging Port Replacement: 6 단계, 이미지 2개 중 1개 Vizio VTAB1008 Charging Port Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the connector at the top of the motherboard by pulling the connector away from the motherboard with fingers or tweezers.
      댓글 쓰기
    5. Vizio VTAB1008 Charging Port Replacement: 7 단계, 이미지 3개 중 1개 Vizio VTAB1008 Charging Port Replacement: 7 단계, 이미지 3개 중 2개 Vizio VTAB1008 Charging Port Replacement: 7 단계, 이미지 3개 중 3개
      • Remove the connector at the side of the motherboard using the opening tool.
      • The connector is covered by a piece of black tape.
      댓글 쓰기
    6. Vizio VTAB1008 Charging Port Replacement: 8 단계, 이미지 2개 중 1개 Vizio VTAB1008 Charging Port Replacement: 8 단계, 이미지 2개 중 2개
      • Remove the red and black wire connector from the motherboard using either fingers or tweezers.
      댓글 쓰기
    7. Vizio VTAB1008 Charging Port Replacement: 9 단계, 이미지 3개 중 1개 Vizio VTAB1008 Charging Port Replacement: 9 단계, 이미지 3개 중 2개 Vizio VTAB1008 Charging Port Replacement: 9 단계, 이미지 3개 중 3개
      • Flip the motherboard over.
      • Directly underneath the USB Charging connector will be four solder points that need to be undone in order to remove the charging port.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Gilberto Ambriz
회원 가입일: 09/29/16
552 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 33
전체 시간: 1,688
