주요 콘텐츠로 건너뛰기
Vizio VTAB1008 Digitizer (Touchscreen) Replacement
필요한 것
  1. Vizio VTAB1008 Digitizer (Touchscreen) Replacement, Vizio VTAB1008 Back Cover Removal: 1 단계, 이미지 2개 중 1개 Vizio VTAB1008 Digitizer (Touchscreen) Replacement, Vizio VTAB1008 Back Cover Removal: 1 단계, 이미지 2개 중 2개
    • Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons.
    • Do not insert the opening tool too far into the tablet as this can damage connectors close to edges of the cover.
    • The angled tip of the opening tool can be wedged into the device by pressing on the back of the opening tool with the thumb. Move the opening tool in a sliding motion to ensure all tabs separate.
    • Corner tabs may require a more forceful prying tool. If needed, carefully insert the metal prying tool into corners to separate the tabs.
  2. Vizio VTAB1008 Digitizer (Touchscreen) Replacement: 2 단계, 이미지 1개 중 1개
    • Look into the tablet for loose connectors.
    • There are three loose connectors: one for the screen, one for the digitizer, and one for the motherboard. They are held in place by the pressure of the backing and screen assemblies.
    • Flip the backing from the button-less side over, being careful not to separate the ribbon connector from the display screen.
  3. Vizio VTAB1008 Digitizer (Touchscreen) Replacement, Digitizer/Touch Screen: 3 단계, 이미지 3개 중 1개 Vizio VTAB1008 Digitizer (Touchscreen) Replacement, Digitizer/Touch Screen: 3 단계, 이미지 3개 중 2개 Vizio VTAB1008 Digitizer (Touchscreen) Replacement, Digitizer/Touch Screen: 3 단계, 이미지 3개 중 3개
    • Remove the two screws present using the J1 Screw bit.
    • The screw has a head size of 4.3 mm and is 3 mm tall.
  4. Vizio VTAB1008 Digitizer (Touchscreen) Replacement: 4 단계, 이미지 3개 중 1개 Vizio VTAB1008 Digitizer (Touchscreen) Replacement: 4 단계, 이미지 3개 중 2개 Vizio VTAB1008 Digitizer (Touchscreen) Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the two brackets accompanying screws by lifting them up and away from the screen.
    • Brackets are 8.5 mm by 6.55 mm.
  5. Vizio VTAB1008 Digitizer (Touchscreen) Replacement: 5 단계, 이미지 3개 중 1개 Vizio VTAB1008 Digitizer (Touchscreen) Replacement: 5 단계, 이미지 3개 중 2개 Vizio VTAB1008 Digitizer (Touchscreen) Replacement: 5 단계, 이미지 3개 중 3개
    • Separate the screen digitizer from the display screen, noting the placement of the quick disconnect ribbon cable.
    • Use a spudger if necessary to assist in the separation.
  6. Vizio VTAB1008 Digitizer (Touchscreen) Replacement: 6 단계, 이미지 2개 중 1개 Vizio VTAB1008 Digitizer (Touchscreen) Replacement: 6 단계, 이미지 2개 중 2개
    • The digitizer should now be able to be freely removed.
결론
작성자
4다른 기여자 명과 함께
Gilberto Ambriz
회원 가입일: 09/29/16
552 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 38
전체 시간: 854
