소개
Volkswagen key fobs come in many different shapes and sizes but there are only two ways to replace their battery. Mine is the easiest of the two. For this you will need no tools, however a spudger might come in handy in dislodging the battery.
Best of luck!
필요한 것
Pull from the small plastic square in the direction of the arrow to release the casing.
Insert a spudger or a pointed object inside of the marked ledge to help release the battery.
Replace the battery and congrats!! You are done.
다른 3명이 해당 안내서를 완성하였습니다.
