주요 콘텐츠로 건너뛰기
Voluas VL001 Motor Assembly Gears Replacement
필요한 것
  1. Voluas VL001 Motor Assembly Gears Replacement, Storage Tank: 1 단계, 이미지 3개 중 1개 Voluas VL001 Motor Assembly Gears Replacement, Storage Tank: 1 단계, 이미지 3개 중 2개 Voluas VL001 Motor Assembly Gears Replacement, Storage Tank: 1 단계, 이미지 3개 중 3개
    • Remove the lid to the storage tank by using the latch and lifting off.
    • Grab the food storage tank on both sides. Depress the tabs that say "Push" on them and lift the tank off.
  2. Voluas VL001 Motor Assembly Gears Replacement, Battery: 2 단계, 이미지 3개 중 1개 Voluas VL001 Motor Assembly Gears Replacement, Battery: 2 단계, 이미지 3개 중 2개 Voluas VL001 Motor Assembly Gears Replacement, Battery: 2 단계, 이미지 3개 중 3개
    • Place your pet feeder upside down.
    • Squeeze the lock and remove the battery cover.
    • Remove the three 1.5V D alkaline batteries.
  3. Voluas VL001 Motor Assembly Gears Replacement, Housing: 3 단계, 이미지 3개 중 1개 Voluas VL001 Motor Assembly Gears Replacement, Housing: 3 단계, 이미지 3개 중 2개 Voluas VL001 Motor Assembly Gears Replacement, Housing: 3 단계, 이미지 3개 중 3개
    • Insert a metal spudger under the adhesive part of each rubber foot.
    • Pry the foot off.
  4. Voluas VL001 Motor Assembly Gears Replacement: 4 단계, 이미지 2개 중 1개 Voluas VL001 Motor Assembly Gears Replacement: 4 단계, 이미지 2개 중 2개
    • Remove four screws from the corners of the device using a Phillips #2 screwdriver.
    • These holes were previously covered by the rubber feet.
    • Using the magnetic tip of the screwdriver, carefully lift the screw out of the hole.
  5. Voluas VL001 Motor Assembly Gears Replacement: 5 단계, 이미지 1개 중 1개
    • Turn the device over so it is oriented right-side up.
    • Lift the top part of the feeder off, exposing the mechanisms that run the feeder.
  6. Voluas VL001 Motor Assembly Gears Replacement, Motor Assembly Gears: 6 단계, 이미지 3개 중 1개 Voluas VL001 Motor Assembly Gears Replacement, Motor Assembly Gears: 6 단계, 이미지 3개 중 2개 Voluas VL001 Motor Assembly Gears Replacement, Motor Assembly Gears: 6 단계, 이미지 3개 중 3개
    • Using a Phillips #2 screwdriver, remove the six screws that hold the motor housing on to the device.
  7. Voluas VL001 Motor Assembly Gears Replacement: 7 단계, 이미지 1개 중 1개
    • Lift the electric motor from its housing and move it aside.
  8. Voluas VL001 Motor Assembly Gears Replacement: 8 단계, 이미지 2개 중 1개 Voluas VL001 Motor Assembly Gears Replacement: 8 단계, 이미지 2개 중 2개
    • Use the tweezers to remove the first gear that is placed on top.
  9. Voluas VL001 Motor Assembly Gears Replacement: 9 단계, 이미지 2개 중 1개 Voluas VL001 Motor Assembly Gears Replacement: 9 단계, 이미지 2개 중 2개
    • Use the tweezers to gently remove the second gear.
  10. Voluas VL001 Motor Assembly Gears Replacement: 10 단계, 이미지 2개 중 1개 Voluas VL001 Motor Assembly Gears Replacement: 10 단계, 이미지 2개 중 2개
    • Use the tweezers to gently remove the third gear.
결론
작성자
2다른 기여자 명과 함께
Jade Thomson
회원 가입일: 01/30/24
699 평판
안내서 6개를 작성함
Utah Tech University, Team 1-3, McMurrin Spring 2024 Utah Tech University, Team 1-3, McMurrin Spring 2024 회원
UTAHTECH-MCMURRIN-S24S1G3
2 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 6
전체 시간: 121
