주요 콘텐츠로 건너뛰기
Vornado 133 Compact Air Circulator Fan Blade Replacement
필요한 것
  1. Vornado 133 Compact Air Circulator Fan Blade Replacement, Grill Cover: 1 단계, 이미지 1/3 Vornado 133 Compact Air Circulator Fan Blade Replacement, Grill Cover: 1 단계, 이미지 2/3 Vornado 133 Compact Air Circulator Fan Blade Replacement, Grill Cover: 1 단계, 이미지 3/3
    • Use a #1 Phillips screwdriver to remove the four 3mm screws.
    • It may be difficult to reach the bottom two screws; tilt the fan housing straight upwards for easier access.
  2. Vornado 133 Compact Air Circulator Fan Blade Replacement: 2 단계, 이미지 1/2 Vornado 133 Compact Air Circulator Fan Blade Replacement: 2 단계, 이미지 2/2
    • Once the screws are removed, turn the fan back over. Use your hands to pull the front grill cover off.
  3. Vornado 133 Compact Air Circulator Fan Blade Replacement, Fan Blades: 3 단계, 이미지 1/3 Vornado 133 Compact Air Circulator Fan Blade Replacement, Fan Blades: 3 단계, 이미지 2/3 Vornado 133 Compact Air Circulator Fan Blade Replacement, Fan Blades: 3 단계, 이미지 3/3
    • Turn the center nut on the blade shaft clockwise to remove the nut, then remove the blades.
    • The nut is removed by turning clockwise, rather than the normal counterclockwise.
결론
Erin Klein
회원 가입일: 07/06/17
453 평판
안내서 3개 작성하였습니다
UW Tacoma, Team S1-G2, Liner Summer 2017 UW Tacoma, Team S1-G2, Liner Summer 2017 회원
UWT-LINER-SU17S1G2
4 회원들
안내서 4개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 37
전체 시간: 2,612
