소개
The Vornado 133 has a small fuse in the plug end as a safety feature; if the fuse has burnt out, your fan will not start. This guide will illustrate how to remove and replace the fuse.
필요한 것
Use a pair of tweezers or a small plastic spudger to remove the fuse from the fuse casing. Remove the end nearer to the fan body first, then the end nearer to the plug end.
very informative. A ok
The information on the fuse is not useful. It needs to include the size, because the link to crapazon shows about 500 different sizes.
hankthedog - 답글
Follow these instructions in reverse order to install the new fuse and close the access panel.
다른 11명이 해당 안내서를 완성하였습니다.
댓글 10개
Great post! This saved me $60 from buying a new fan! Thank you!
Thanks for posting. Ordered a pack of 50 fuses from amazon for $7.97
Fast-acting or slow-acting?
The fuse isnt clear glass its red strip white under what that mean
The fuse is not clear it has whitestrip with red strip what that
I replaced the fuse and still will not turn on. Ive only had the fan for 6 months
