주요 콘텐츠로 건너뛰기
Vostro 1720 Memory Module Replacement
필요한 것
  1. Vostro 1720 Memory Module Replacement, Sliding the Latches: 1 단계, 이미지 1/1
    • Slide the battery lock latches into the unlocked position.
  2. Vostro 1720 Memory Module Replacement, Slide the Battery: 2 단계, 이미지 1/1
    • Slide the battery toward the back of the computer to remove.
  3. Vostro 1720 Memory Module Replacement, Remove the Screws: 3 단계, 이미지 1/1
    • Remove the eight screws from the access panel.
    • Lift the edge of the access panel that is closest to the center of the computer.
  4. Vostro 1720 Memory Module Replacement, Remove the Access Panel: 5 단계, 이미지 1/1
    • Remove the access panel.
  5. Vostro 1720 Memory Module Replacement, Removing the Memory Module: 6 단계, 이미지 1/1
    • If applicable, remove the top memory module by using your fingertips to carefully spread apart the securing clips on each end of the top memory module connector until the memory module pops up.
  6. Vostro 1720 Memory Module Replacement, Sliding the Memory Module: 7 단계, 이미지 1/1
    • Slide the memory module out of the socket.
  7. Vostro 1720 Memory Module Replacement, Spreading apart the Clips: 8 단계, 이미지 1/1
    • If applicable, remove the bottom memory module by using your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
  8. Vostro 1720 Memory Module Replacement, Sliding the Memory Module: 9 단계, 이미지 1/1
결승점
Johnathan Hammond
회원 가입일: 02/28/18
44,830 평판
안내서 408개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,985개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 70
