주요 콘텐츠로 건너뛰기
Vtech InnoTab 3 Rear Panel Diassembly
필요한 것
  1. Vtech InnoTab 3 Rear Panel Diassembly, Rear Panel: 1 단계, 이미지 1/3 Vtech InnoTab 3 Rear Panel Diassembly, Rear Panel: 1 단계, 이미지 2/3 Vtech InnoTab 3 Rear Panel Diassembly, Rear Panel: 1 단계, 이미지 3/3
    • Slide the battery compartment door lock down.
    • While still holding the battery compartment lock down, slide the two battery doors outwards on either side of the device.
    • Carefully remove the batteries from the battery compartment.
    • The standard option for the InnoTab 3 is four AA batteries. Vtech also offers a rechargeable battery online, but both battery options are removed from the device the same way.
  2. Vtech InnoTab 3 Rear Panel Diassembly: 2 단계, 이미지 1/1
    • Remove the six 7.6mm screws found in the battery compartment using a PH00 screwdriver.
  3. Vtech InnoTab 3 Rear Panel Diassembly: 3 단계, 이미지 1/3 Vtech InnoTab 3 Rear Panel Diassembly: 3 단계, 이미지 2/3 Vtech InnoTab 3 Rear Panel Diassembly: 3 단계, 이미지 3/3
    • There are three hidden screws on the back of the device, two at the top and one near the bottom.
    • Using a nylon or metal spudger, remove the three caps that hide the screws.
    • Remove the 5mm screw near the bottom and the two 7.6mm at the top using a PH00 screwdriver.
  4. Vtech InnoTab 3 Rear Panel Diassembly: 4 단계, 이미지 1/1
    • Carefully separate the back panel from the front panel revealing the motherboard connected to the front panel.
결론
Brooke Livingston
회원 가입일: 03/11/15
110 평판
안내서 1개 작성함
Colorado Springs, Team 5-4, Panko Spring 2015 Colorado Springs, Team 5-4, Panko Spring 2015 회원
UCCS-PANKO-S15S5G4
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 10
전체 시간: 1,131
