주요 콘텐츠로 건너뛰기
Vtech InnoTab 3S Rear Panel Replacement
필요한 것
  1. Vtech InnoTab 3S Rear Panel Replacement, Rear Panel: 1 단계, 이미지 1/3 Vtech InnoTab 3S Rear Panel Replacement, Rear Panel: 1 단계, 이미지 2/3 Vtech InnoTab 3S Rear Panel Replacement, Rear Panel: 1 단계, 이미지 3/3
    • While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
    • Remove the batteries from the device.
  2. Vtech InnoTab 3S Rear Panel Replacement: 2 단계, 이미지 1/2 Vtech InnoTab 3S Rear Panel Replacement: 2 단계, 이미지 2/2
    • Remove six 7 mm screws from the interior of the battery compartment using a Phillips #1 screwdriver.
  3. Vtech InnoTab 3S Rear Panel Replacement: 3 단계, 이미지 1/3 Vtech InnoTab 3S Rear Panel Replacement: 3 단계, 이미지 2/3 Vtech InnoTab 3S Rear Panel Replacement: 3 단계, 이미지 3/3
    • Using a nylon spudger, remove the five caps that hide the screws.
    • Potential for device damage: Be careful not to scrape the plastic from the device using the spudger.
    • When removing the caps, hold the spudger vertical to the board to make removal easier. Also try to push in with your spudger pointing towards the bottom of the device.
    • Remove the five 5 mm Phillips #1 screws from the rear panel of the device.
  4. Vtech InnoTab 3S Rear Panel Replacement: 4 단계, 이미지 1/1
    • Carefully remove the rear panel from the front panel of the device.
    • Once the rear panel is removed, you'll be able to see the motherboard and other components within the Vtech InnoTab 3s.
결론
Karina Garcia
회원 가입일: 08/30/15
836 평판
안내서 6개 작성하였습니다
USF Tampa, Team 8-2, Eyestone Fall 2015 USF Tampa, Team 8-2, Eyestone Fall 2015 회원
USFT-EYESTONE-F15S8G2
4 회원들
안내서 9개 작성하였습니다
댓글 한 개
too dumb i tryed 7 times it didnt work i reat this 1000000-/10
Kyron Ostrander - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 12
전체 시간: 656
