주요 콘텐츠로 건너뛰기
Vtech InnoTab 3S Screen Replacement
필요한 것
  1. Vtech InnoTab 3S Screen Replacement, Rear Panel: 1 단계, 이미지 1/3 Vtech InnoTab 3S Screen Replacement, Rear Panel: 1 단계, 이미지 2/3 Vtech InnoTab 3S Screen Replacement, Rear Panel: 1 단계, 이미지 3/3
    • While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
    • Remove the batteries from the device.
  2. Vtech InnoTab 3S Screen Replacement: 2 단계, 이미지 1/2 Vtech InnoTab 3S Screen Replacement: 2 단계, 이미지 2/2
    • Remove six 7 mm screws from the interior of the battery compartment using a Phillips #1 screwdriver.
  3. Vtech InnoTab 3S Screen Replacement: 3 단계, 이미지 1/3 Vtech InnoTab 3S Screen Replacement: 3 단계, 이미지 2/3 Vtech InnoTab 3S Screen Replacement: 3 단계, 이미지 3/3
    • Using a nylon spudger, remove the five caps that hide the screws.
    • Potential for device damage: Be careful not to scrape the plastic from the device using the spudger.
    • When removing the caps, hold the spudger vertical to the board to make removal easier. Also try to push in with your spudger pointing towards the bottom of the device.
    • Remove the five 5 mm Phillips #1 screws from the rear panel of the device.
  4. Vtech InnoTab 3S Screen Replacement: 4 단계, 이미지 1/1
    • Carefully remove the rear panel from the front panel of the device.
    • Once the rear panel is removed, you'll be able to see the motherboard and other components within the Vtech InnoTab 3s.
  5. Vtech InnoTab 3S Screen Replacement, Motherboard: 5 단계, 이미지 1/2 Vtech InnoTab 3S Screen Replacement, Motherboard: 5 단계, 이미지 2/2
    • Remove the six screws that secure the motherboard to the front panel of the device using a Phillips #1 screwdriver.
    • Remove the other 5mm screws that secure the charger port and the buttons to the inside of the front panel.
    • Remove the six 3 mm screws securing the battery clip.
  6. Vtech InnoTab 3S Screen Replacement: 6 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using the tweezers, remove one battery clip from each corner (four total) of the Vtech InnoTab 3s.
    • With the tweezers, unsecure the charging port, headphone port, and the light switch button from the front panel of the device.
    • Potential for device damage: Avoid forceful movements when removing the motherboard to prevent damage of device components.
  7. Vtech InnoTab 3S Screen Replacement, Screen: 7 단계, 이미지 1/3 Vtech InnoTab 3S Screen Replacement, Screen: 7 단계, 이미지 2/3 Vtech InnoTab 3S Screen Replacement, Screen: 7 단계, 이미지 3/3
    • Open the clip holding the screen plug with the yellow film.
    • The clip securing the screen is located at the top of the motherboard.
    • Remove all seven of the 5mm screws on the motherboard to separate the motherboard from the screen.
  8. Vtech InnoTab 3S Screen Replacement: 8 단계, 이미지 1/2 Vtech InnoTab 3S Screen Replacement: 8 단계, 이미지 2/2
    • Avoid forceful movements when separating the screen from the motherboard.
    • Carefully separate the motherboard from the device screen. Replace the damaged screen with an operational one.
결론
Karina Garcia
회원 가입일: 08/30/15
836 평판
안내서 6개 작성하였습니다
USF Tampa, Team 8-2, Eyestone Fall 2015 USF Tampa, Team 8-2, Eyestone Fall 2015 회원
USFT-EYESTONE-F15S8G2
4 회원들
안내서 9개 작성하였습니다
댓글 4개
What is the part number for the screen. Where can I buy one. Thank you.
david goodwin - 답글
what is the size of the screen
Adrienne Dooms - 답글
My grandson dropped his innotab 3 and now the screen is all scrambled. Can this be fixed? It did not crack the screen.
charma1963 - 답글
Where can I buy the replacement screen for the Vtech innotab 3S
Michael Kurrus - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 2,243
