주요 콘텐츠로 건너뛰기
Vtech InnoTab 3S USB Port Replacement
필요한 것
  1. Vtech InnoTab 3S USB Port Replacement, Rear Panel: 1 단계, 이미지 3개 중 1개 Vtech InnoTab 3S USB Port Replacement, Rear Panel: 1 단계, 이미지 3개 중 2개 Vtech InnoTab 3S USB Port Replacement, Rear Panel: 1 단계, 이미지 3개 중 3개
    • While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
    • Remove the batteries from the device.
  2. Vtech InnoTab 3S USB Port Replacement: 2 단계, 이미지 2개 중 1개 Vtech InnoTab 3S USB Port Replacement: 2 단계, 이미지 2개 중 2개
    • Remove six 7 mm screws from the interior of the battery compartment using a Phillips #1 screwdriver.
  3. Vtech InnoTab 3S USB Port Replacement: 3 단계, 이미지 3개 중 1개 Vtech InnoTab 3S USB Port Replacement: 3 단계, 이미지 3개 중 2개 Vtech InnoTab 3S USB Port Replacement: 3 단계, 이미지 3개 중 3개
    • Using a nylon spudger, remove the five caps that hide the screws.
    • Potential for device damage: Be careful not to scrape the plastic from the device using the spudger.
    • When removing the caps, hold the spudger vertical to the board to make removal easier. Also try to push in with your spudger pointing towards the bottom of the device.
    • Remove the five 5 mm Phillips #1 screws from the rear panel of the device.
  4. Vtech InnoTab 3S USB Port Replacement: 4 단계, 이미지 1개 중 1개
    • Carefully remove the rear panel from the front panel of the device.
    • Once the rear panel is removed, you'll be able to see the motherboard and other components within the Vtech InnoTab 3s.
  5. Vtech InnoTab 3S USB Port Replacement, Motherboard: 5 단계, 이미지 2개 중 1개 Vtech InnoTab 3S USB Port Replacement, Motherboard: 5 단계, 이미지 2개 중 2개
    • Remove the six screws that secure the motherboard to the front panel of the device using a Phillips #1 screwdriver.
    • Remove the other 5mm screws that secure the charger port and the buttons to the inside of the front panel.
    • Remove the six 3 mm screws securing the battery clip.
  6. Vtech InnoTab 3S USB Port Replacement: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using the tweezers, remove one battery clip from each corner (four total) of the Vtech InnoTab 3s.
    • With the tweezers, unsecure the charging port, headphone port, and the light switch button from the front panel of the device.
    • Potential for device damage: Avoid forceful movements when removing the motherboard to prevent damage of device components.
  7. Vtech InnoTab 3S USB Port Replacement, USB Port: 7 단계, 이미지 3개 중 1개 Vtech InnoTab 3S USB Port Replacement, USB Port: 7 단계, 이미지 3개 중 2개 Vtech InnoTab 3S USB Port Replacement, USB Port: 7 단계, 이미지 3개 중 3개
    • The mini USB port is located near the top of the device and is secured by four metal prongs underneath the port.
    • Facing the underside of the USB port, solder the metal prongs securing the USB port to the device.
    • Avoid forceful movements when soldering to prevent damage of device components and avoid personal injury.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
taweewatchulikavit
회원 가입일: 08/27/15
398 평판
안내서 3개를 작성함
USF Tampa, Team 8-2, Eyestone Fall 2015 USF Tampa, Team 8-2, Eyestone Fall 2015 회원
USFT-EYESTONE-F15S8G2
4 회원들
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 14
전체 시간: 1,441
