주요 콘텐츠로 건너뛰기
Vtech Kidibeats Drum Set Battery Replacement
필요한 것
  1. Vtech Kidibeats Drum Set Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Locate the battery panel that is centered between the three leg supports at the bottom of the drum set.
  2. Vtech Kidibeats Drum Set Battery Replacement: 2 단계, 이미지 1/1
    • To remove the battery panel, loosen the 10 mm panel screw using a flathead 4.0 screwdriver.
    • You can also use a small coin to loosen the screw.
  3. Vtech Kidibeats Drum Set Battery Replacement: 3 단계, 이미지 1/1
    • Using your fingers, pry open and remove the back battery panel.
  4. Vtech Kidibeats Drum Set Battery Replacement: 4 단계, 이미지 1/1
    • Use your fingers to remove each battery from its housing.
    • When inserting the new batteries, remember to match them according to the image displayed on the battery panel.
결론
Aaron Klementowski
회원 가입일: 02/09/16
820 평판
안내서 6개 작성하였습니다
USF Tampa, Team 2-8, Cagle Spring 2016 USF Tampa, Team 2-8, Cagle Spring 2016 회원
USFT-CAGLE-S16S2G8
2 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 14
전체 시간: 897
