소개
A broken or cracked cymbal can be very hazardous to small children. Additionally, a damaged cymbal could prevent the drum set from working properly. This guide is designed to show how to correctly replace the green cymbal in order restore your drum set to a safe and functioning condition.
필요한 것
Locate the battery panel that is centered between the three leg supports at the bottom of the drum set.
다른 한 분이 해당 안내서를 완성하였습니다.
