주요 콘텐츠로 건너뛰기
Vtech Kidizoom Smart Watch DX Faceplate Replacement
필요한 것
  1. Vtech Kidizoom Smart Watch DX Faceplate Replacement, Faceplate: 1 단계, 이미지 1/1
    • Flip the watch so that the screen faces upward.
  2. Vtech Kidizoom Smart Watch DX Faceplate Replacement: 2 단계, 이미지 1/1
    • Use a plastic opening tool to gently pry the edges of the faceplate away from the watch.
    • You may hear some popping sounds as you are removing the faceplate. This is normal.
  3. Vtech Kidizoom Smart Watch DX Faceplate Replacement: 3 단계, 이미지 1/1
    • Pull the faceplate fully apart from the watch.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Jordan RiberSmith
회원 가입일: 01/20/16
755 평판
안내서 2개 작성하였습니다
USF Tampa, Team 10-6, Remmell Spring 2016 USF Tampa, Team 10-6, Remmell Spring 2016 회원
USFT-REMMELL-S16S10G6
4 회원들
안내서 12개 작성하였습니다
댓글 6개
Where can I get a new faceplate???
Eileen Osborne - 답글
Yes even I have same Question ..Where do I get this faceplate??
Manisha Divekar - 답글
Did you get an answer on you question. I need a faceplate too
Please advise
michele - 답글
Where can I get a replacement faceplate
cram66bum - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 17
전체 시간: 6,003
