주요 콘텐츠로 건너뛰기
Vtech Touch and Swipe Baby Phone Power Switch Replacement
필요한 것
  1. Vtech Touch and Swipe Baby Phone Power Switch Replacement, Battery: 1 단계, 이미지 2개 중 1개 Vtech Touch and Swipe Baby Phone Power Switch Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
  2. Vtech Touch and Swipe Baby Phone Power Switch Replacement: 2 단계, 이미지 3개 중 1개 Vtech Touch and Swipe Baby Phone Power Switch Replacement: 2 단계, 이미지 3개 중 2개 Vtech Touch and Swipe Baby Phone Power Switch Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
  3. Vtech Touch and Swipe Baby Phone Power Switch Replacement: 3 단계, 이미지 3개 중 1개 Vtech Touch and Swipe Baby Phone Power Switch Replacement: 3 단계, 이미지 3개 중 2개 Vtech Touch and Swipe Baby Phone Power Switch Replacement: 3 단계, 이미지 3개 중 3개
    • When reassembling, align the notch on the battery panel with the slot on the phone.
  4. Vtech Touch and Swipe Baby Phone Power Switch Replacement, Power Switch: 4 단계, 이미지 2개 중 1개 Vtech Touch and Swipe Baby Phone Power Switch Replacement, Power Switch: 4 단계, 이미지 2개 중 2개
    • Remove 4 13.8mm screws holding the device back using a Phillips #1 screw driver.
  5. Vtech Touch and Swipe Baby Phone Power Switch Replacement: 5 단계, 이미지 3개 중 1개 Vtech Touch and Swipe Baby Phone Power Switch Replacement: 5 단계, 이미지 3개 중 2개 Vtech Touch and Swipe Baby Phone Power Switch Replacement: 5 단계, 이미지 3개 중 3개
    • Lift directly up to remove the switch and lay the wire down to the side.
    • Once the switch has been taken out you can remove the switch's casing.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
tellocordova
회원 가입일: 09/04/15
342 평판
안내서 2개를 작성함
USF Tampa, Team 2-4, Sullivan Fall 2015 USF Tampa, Team 2-4, Sullivan Fall 2015 회원
USFT-SULLIVAN-F15S2G4
3 회원들
안내서 12개를 작성함
2가이드 댓글
Good work.
I have done it the same way,
the wire at the switch was bad soldered,
but it was easy to repair it and i soldered it new.
Nice.
Schwarzstein - 답글
My baby’s phone keeps turning itself off. The switch is in the ON position but it keeps turning OFF and singing the off song. I have opened the phone and even held the switch to ON but it still keeps turning OFF even without the switch moving. Any suggestions?
shakinsher - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 14
전체 시간: 844
