주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Vtech kidizoom camera disassembly
필요한 것
  1. Vtech kidizoom camera disassembly, Vtech kidizoom camera disassembly: 1 단계, 이미지 3개 중 1개 Vtech kidizoom camera disassembly, Vtech kidizoom camera disassembly: 1 단계, 이미지 3개 중 2개 Vtech kidizoom camera disassembly, Vtech kidizoom camera disassembly: 1 단계, 이미지 3개 중 3개
    • Camera
    댓글 쓰기
  2. Vtech kidizoom camera disassembly: 2 단계, 이미지 3개 중 1개 Vtech kidizoom camera disassembly: 2 단계, 이미지 3개 중 2개 Vtech kidizoom camera disassembly: 2 단계, 이미지 3개 중 3개
    • push and open
    댓글 쓰기
  3. Vtech kidizoom camera disassembly: 3 단계, 이미지 3개 중 1개 Vtech kidizoom camera disassembly: 3 단계, 이미지 3개 중 2개 Vtech kidizoom camera disassembly: 3 단계, 이미지 3개 중 3개
    • Insérer un commentaire.
    댓글 쓰기
  4. Vtech kidizoom camera disassembly: 4 단계, 이미지 3개 중 1개 Vtech kidizoom camera disassembly: 4 단계, 이미지 3개 중 2개 Vtech kidizoom camera disassembly: 4 단계, 이미지 3개 중 3개
    댓글 쓰기
  5. Vtech kidizoom camera disassembly: 5 단계, 이미지 1개 중 1개
    댓글 쓰기
결론
Pour réassembler votre appareil, suivez les instructions dans l'ordre inverse.
취소: 해당 안내서를 완성하지 않았습니다.
다른 13명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
olixcomtest
회원 가입일: 11/06/16
377 평판
안내서 1개를 작성함
5가이드 댓글
In the very first step be aware that the you just need to remove the paper ring. In the photo above this is pink and on mine it was orange.
I made the mistake of thinking I had to use some force with a screwdriver, to remove the ring on the front, which resulted in me scratching the chrome ring.
Once you have removed the paper ring, you can see the screws (or they may be under the left over sticky backing to the paper but are easy to find).
These photos were extremely helpful and I was able to repair the camera.
The problem with mine, was that it would not switch on. We replaced the batteries, but still no good.
After using the above photos, I opened the camera and discovered that one of the two cables to one of the battery holders, had come loose.
In the process of resoldering the broken cable, the second battery cable also came off … mainly due to the use of VERY thin wire and minimum solder.
Anyway, the camera is now working again and my son is very happy.
Chris - 답글 공유
Thank you! It worked great with the Kidizoom Touch 5.0, Same principle. The Trigger was Stuck and with your instruction i was able to Open and fix it!
Flo - 답글 공유
Thanks! I had the newer Kidzoom touch 5.0 model. It works similar but after the same principle: First remove the camera objective ring. I could repair the (mechanical) damage…
Klausklaus - 답글 공유
Thanks a lot, also in my case the trigger button of the kidizoom touch 5.0 was stuck. I followed the instruction and was able to fix it. Thereby I scratched a bit the silver ring. This may could be prevented if the locator of the notches are known/considered while trying to remove the outer ring.
DAVID - 답글 공유
Hi, has anyone any experience of taking the Vtech Kidizoom Action Cam HD apart mine charges but will not switch on (loose wire i suspect) but i can't see how to disassemble. Cheers Alan.
Alan Mitchell - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 45
지난 30일: 227
전체 시간: 19,570
