주요 콘텐츠로 건너뛰기
VuPoint DC-ST210-VP LCD Screen Replacement
필요한 것
  1. VuPoint DC-ST210-VP LCD Screen Replacement, Turn Off/Remove Batteries: 1 단계, 이미지 1개 중 1개
    • Hold the on/off button for 3 seconds until the screen is black.
    • Remove batteries by placing thumb on battery plate cover sliding it down to expose batteries.
    • Turn camera upside down to allow the batteries to fall out.
  2. VuPoint DC-ST210-VP LCD Screen Replacement, Remove Screws: 2 단계, 이미지 3개 중 1개 VuPoint DC-ST210-VP LCD Screen Replacement, Remove Screws: 2 단계, 이미지 3개 중 2개 VuPoint DC-ST210-VP LCD Screen Replacement, Remove Screws: 2 단계, 이미지 3개 중 3개
    • There are 5 (4.5mm in length) screws on the sides of the camera that need to be removed. Use a Phillips #000 screwdriver to remove all screws.
    • Remove 2 screws on the right side of the camera, and store them on a magnetic mat.
    • Remove 2 screws on the bottom of the camera, and store them on a magnetic mat.
    • Remove 1 screw on the left side of the camera, and store it on a magnetic mat.
  3. VuPoint DC-ST210-VP LCD Screen Replacement, Pry Backplate Off: 3 단계, 이미지 2개 중 1개 VuPoint DC-ST210-VP LCD Screen Replacement, Pry Backplate Off: 3 단계, 이미지 2개 중 2개
    • Using a prying tool or fingernail, gently separate the back plate from the front plate, exposing the inside of the camera.
  4. VuPoint DC-ST210-VP LCD Screen Replacement, Remove Circuit Board Screws: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $16.96
    • Using a Phillips #00 screwdriver, remove the 5 (3.5mm in length) screws shown to the left.
    • Remember to place small screws on magnetic mat or in a container.
  5. VuPoint DC-ST210-VP LCD Screen Replacement, Seperate Circuit Board: 5 단계, 이미지 3개 중 1개 VuPoint DC-ST210-VP LCD Screen Replacement, Seperate Circuit Board: 5 단계, 이미지 3개 중 2개 VuPoint DC-ST210-VP LCD Screen Replacement, Seperate Circuit Board: 5 단계, 이미지 3개 중 3개
    • Using a pry tool or fingernail, gently pry the circuit board from the base.
    • Gently lift the lower right hand corner of the circuit board, separating it from the base.
  6. VuPoint DC-ST210-VP LCD Screen Replacement, Remove LCD from Connector: 6 단계, 이미지 3개 중 1개 VuPoint DC-ST210-VP LCD Screen Replacement, Remove LCD from Connector: 6 단계, 이미지 3개 중 2개 VuPoint DC-ST210-VP LCD Screen Replacement, Remove LCD from Connector: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Locate LCD and gently bend it back to reveal ribbon cable connector.
    • Using small screw driver or tweezers gently slide the edges of the ribbon lock towards the direction of the cable.
    • Once the lock is opened, use tweezers to slide the ribbon cable from the connector.
    • Replace LCD as needed and repeat steps in reverse to reassemble.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Lincoln Thompson
회원 가입일: 10/20/14
32 평판
안내서 2개를 작성함
Baylor, Team 8-15, Williams Fall 2014 Baylor, Team 8-15, Williams Fall 2014 회원
BU-WILLIAMS-F14S8G15
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 11
전체 시간: 517
