주요 콘텐츠로 건너뛰기
VuPoint DC-ST210-VP Shutter Button Replacement
필요한 것
  1. VuPoint DC-ST210-VP Shutter Button Replacement, Turn Off/Remove Batteries: 1 단계, 이미지 1개 중 1개
    • Hold the on/off button for 3 seconds until the screen is black.
    • Remove batteries by placing thumb on battery plate cover sliding it down to expose batteries.
    • Turn camera upside down to allow the batteries to fall out.
  2. VuPoint DC-ST210-VP Shutter Button Replacement, Remove Screws: 2 단계, 이미지 3개 중 1개 VuPoint DC-ST210-VP Shutter Button Replacement, Remove Screws: 2 단계, 이미지 3개 중 2개 VuPoint DC-ST210-VP Shutter Button Replacement, Remove Screws: 2 단계, 이미지 3개 중 3개
    • There are 5 (4.5mm in length) screws on the sides of the camera that need to be removed. Use a Phillips #000 screwdriver to remove all screws.
    • Remove 2 screws on the right side of the camera, and store them on a magnetic mat.
    • Remove 2 screws on the bottom of the camera, and store them on a magnetic mat.
    • Remove 1 screw on the left side of the camera, and store it on a magnetic mat.
  3. VuPoint DC-ST210-VP Shutter Button Replacement, Pry Backplate Off: 3 단계, 이미지 2개 중 1개 VuPoint DC-ST210-VP Shutter Button Replacement, Pry Backplate Off: 3 단계, 이미지 2개 중 2개
    • Using a prying tool or fingernail, gently separate the back plate from the front plate, exposing the inside of the camera.
  4. VuPoint DC-ST210-VP Shutter Button Replacement, Remove Circuit Board: 4 단계, 이미지 2개 중 1개 VuPoint DC-ST210-VP Shutter Button Replacement, Remove Circuit Board: 4 단계, 이미지 2개 중 2개
    • With the back plate off, use a screw driver to remove the 6 screws shown to the left.
    • Gently separate the circuit board from frame, by prying the circuit board from base.
  5. VuPoint DC-ST210-VP Shutter Button Replacement, Move Plastic Protector: 5 단계, 이미지 1개 중 1개
    • Using your finger rotate the dark grey piece away from the shutter button.
  6. VuPoint DC-ST210-VP Shutter Button Replacement, Remove Shutter Button: 6 단계, 이미지 2개 중 1개 VuPoint DC-ST210-VP Shutter Button Replacement, Remove Shutter Button: 6 단계, 이미지 2개 중 2개
    • Remove the shutter button by gently pressing the button from the top, pushing it towards the inside of the camera. Press shutter button down and wiggle slightly until the shutter button comes loose from housing.
    • Replace as necessary.
결론
작성자
2다른 기여자 명과 함께
Lincoln Thompson
회원 가입일: 10/20/14
32 평판
안내서 2개를 작성함
Baylor, Team 8-15, Williams Fall 2014 Baylor, Team 8-15, Williams Fall 2014 회원
BU-WILLIAMS-F14S8G15
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 10
전체 시간: 378
