주요 콘텐츠로 건너뛰기
Vulcan Venture II VNB14002IE I/O Board Replacement
필요한 것
  1. Vulcan Venture II VNB14002IE I/O Board Replacement, Back Panel: 1 단계, 이미지 1/1
    • Use a J00 screwdriver to unscrew the 10 back-plate screws.
  2. Vulcan Venture II VNB14002IE I/O Board Replacement: 2 단계, 이미지 1/1
    • Gently separate the back panel from the laptop.
  3. Vulcan Venture II VNB14002IE I/O Board Replacement, I/O Board: 3 단계, 이미지 1/1
    • Locate the IO board on the back panel.
  4. Vulcan Venture II VNB14002IE I/O Board Replacement: 4 단계, 이미지 1/2 Vulcan Venture II VNB14002IE I/O Board Replacement: 4 단계, 이미지 2/2
    • Locate the ribbon connector on the IO board, and lift the black bar closest the the ribbon.
    • Pull the ribbon cable away from the connector, releasing it.
  5. Vulcan Venture II VNB14002IE I/O Board Replacement: 5 단계, 이미지 1/2 Vulcan Venture II VNB14002IE I/O Board Replacement: 5 단계, 이미지 2/2
    • Locate the screws on the IO panel, and use the J00+ bit to unscrew them.
  6. Vulcan Venture II VNB14002IE I/O Board Replacement: 6 단계, 이미지 1/1
    • The IO Board is now safe to remove from the computer.
결론
Parish Brandt
회원 가입일: 09/21/18
615 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 508
