주요 콘텐츠로 건너뛰기
Vulcan Venture II VNB14002IE Speaker Replacement
필요한 것
  1. Vulcan Venture II VNB14002IE Speaker Replacement, Back Panel: 1 단계, 이미지 1/1
    • Use a J00 screwdriver to unscrew the 10 back-plate screws.
  2. Vulcan Venture II VNB14002IE Speaker Replacement: 2 단계, 이미지 1/1
    • Gently separate the back panel from the laptop.
  3. Vulcan Venture II VNB14002IE Speaker Replacement, Speaker: 3 단계, 이미지 1/1
    • Locate the speaker modules on the back of the laptop.
    • Gently pry the speakers out of the plastic casing using your finger or the blue plastic pry tool.
  4. Vulcan Venture II VNB14002IE Speaker Replacement: 4 단계, 이미지 1/1
    • Gently pull out the speaker wire connector from the motherboard.
  5. Vulcan Venture II VNB14002IE Speaker Replacement: 5 단계, 이미지 1/1
    • Unwrap the wires from their holders and remove the speaker modules.
    • When re-inserting the speakers, make sure the wires are correctly wrapped around the plastic holders, and that the speaker wire goes underneath the touch pad connector wire, as it was before.
결론
Parish Brandt
회원 가입일: 09/21/18
615 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 321
